posted 12-21-2009 11:51 AM ET (US)
I found this on a different site dated 2002.
Working on on my Bennett w351 pump, the information seems to be accurate.
The system is setup with an electric motor that runs Forward (Blue wire) and Reverse (Yellow wire) to provide the down and up action for the trim tabs. It also has two solenoid valves to separate which tab to be moved. There is a Red wired one for Port and a Green wired one for Stbd, just like navigation!
The following is a Trouble Shooting Guide for the system:
Red = Port Valve
Green = Stbd Valve
Yellow = Motor reverse, tab(s) up
Blue = Motor forward, tab(s) down
Orange = Power, located at trim tab control
Black = Ground, found on backside of HPU
Please conduct the following hot wiring tests starting at the trim tab control and working your back the HPU. Ensure you are working with proper voltage (12 volts for most systems, 20 amp fuse):
Blue + Red + Power = Port tab down
Blue + Green + Power = Stbd tab down
Blue + Red + Green + Power = Both tabs down
Yellow + Red + Power = Port tab up
Yellow + Green + Power = Stbd tab up
Yellow + Red + Green + Power = Both tabs up
Please get back to me with your findings and with the age of your system, since it has a 5 year warranty! You can contact me at the email address or phone number below.
I look forward to your reply.
Sincerely,
MJ Thomas
Bennett Marine, Inc.
Client Services
954-427-1400
954-480-2897 Fax[edited]
