ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Repairs/Mods Neutral safety lock
Author | Topic: Neutral safety lock |
dscew |
posted 03-25-2010 07:58 PM ET (US)
When I re-powered my old Katama with a new 60 HP Mercury engine, I installed a standard binnacle Merc single lever control. While it doesn't allow starting unless the shifter is in neutral, I'd like it to have an automatic neutral safety lock, which would prevent inadvertant shifting into gear. Does anyone have or know of this type of control, either from Mercury or Teleflex? Part numbers and suppliers would be appreciated. |
number9 |
posted 03-26-2010 12:22 PM ET (US)
Believe you may be referring to a neutral lock release/throttle interlock. Those are usually found on side mount controls. Teleflex has had it as an option on their CH7500/7600 top mount controls. http://www.jamestowndistributors.com/userportal/pdfs/Teleflex/ TMTechCat-Controls%28v4_0%29CH1700_CH7500_CH7600.pdf |
dscew |
posted 03-26-2010 04:24 PM ET (US)
Thank you. I did see the Teleflex ones on their website, wasn't sure if it was the right application. |
