  Repair Hydraulic Steering Hose
Author Topic:   Repair Hydraulic Steering Hose
flukerd2 posted 08-01-2010 05:11 AM ET (US)   Profile for flukerd2   Send Email to flukerd2
A hydraulic line coming out of the stern going into my Telflex steering cylinder is leaking. It looks like the top of the line wore off from rubbing against another line. The previous owner had two lines on top of each other. I have since gotten the two lines away from each other. Is there any way to stop the line from leaking without replacing the entire line. Thanks.
jimh posted 08-01-2010 08:17 AM ET (US)     Profile for jimh  Send Email to jimh
If the abrasion that caused the leak was due to the hose rubbing against another hose of the same type, the other hose should also be abraded and ready to begin leaking.
Cut the hose at the leak, cutting away the portion that is damaged. Insert a coupling and connect the two side of the hose back together. Pressure test. Bleed the system. Or, buy new hoses for both.
L H G posted 08-02-2010 07:16 PM ET (US)     Profile for L H G
Teleflex says leaking or damaged hydraulic lines can't be fixed, and must be replaced.
Martino posted 08-02-2010 10:23 PM ET (US)     Profile for Martino  Send Email to Martino
Hydraulic hoses operate under extremely high pressure. Special presses are needed to properly install the fittings. A repair should only be attempted by a pro with the correct equipment and experience. Most hyraulic shops can probably make you a new hose for nearly the same price as repairing yours.
Tom W Clark posted 08-02-2010 10:40 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
There is no reason to attempt to "repair" a SeaStar Hydraulic steering hose, just replace it.
Actually replace both hoses while you are at it. That way both hoses are the same age and you only have to bleed the system the one time.
