  MONTAUK 17: Kodiak Bait Tank
Author Topic:   MONTAUK 17: Kodiak Bait Tank
Newtauk1 posted 01-26-2011 10:10 PM ET (US)   Profile for Newtauk1   Send Email to Newtauk1
I have seen a few references to installing a 14-gallon Kodiak-brand bait tank between the center console and [reversible pilot seat] on a Montauk. [Seeks a] photo of this installation.
jimh posted 01-26-2011 10:21 PM ET (US)     Profile for jimh  Send Email to jimh
I would be interested to see how a bait tank could be installed between the console and the reversible pilot seat on a MONTAUK. That space is where the helmsman usually stands.
Newtauk1 posted 01-26-2011 10:38 PM ET (US)     Profile for Newtauk1  Send Email to Newtauk1
Agreed Jim. Hence my inquiry for a photo. A few members have referenced this set up back in 2005 and 2006. I thought it best to strart a new thread rather then digging up an old one.
http://continuouswave.com/ubb/Forum1/HTML/003159.html
Newtauk1 posted 01-26-2011 10:44 PM ET (US)     Profile for Newtauk1  Send Email to Newtauk1
this psot as well.
http://continuouswave.com/ubb/Forum1/HTML/006774.html
newt posted 01-30-2011 01:10 PM ET (US)     Profile for newt  Send Email to newt
I have not owned a Montauk for many years now, but can't imagine that placing the bait tank between the console and RPS would work well. The tank would need to be too small for the mackerel (knowing where you fish, I am assuming mackerel are your live bait), and how could you operate the boat?
Your best option is a removable bait tank located somewhere in the rear cockpit or in front of the console. For a couple years, I used a home made bait tank that did not require any permanent plumbing. To fill the tank, I would drop a small bilge pump over the side, then to circulate the water the bilge pump went into the bait tank.
I don't need the home made contraption anymore, but think I still have it if you wanted to borrow it for next season to try out until you decide what your permanent solution will be.
Newtauk1 posted 01-30-2011 11:14 PM ET (US)     Profile for Newtauk1  Send Email to Newtauk1
Newt- thanks for the offer. You are the best. I went ahead and bought the 14 gal tank.(Kodiak) Plan to use it behind the rps and remove when not fishing. I think the guy who rigged it "between" the RPS and CC. did it off center. I plan to use a Rule pump over or attached to the transom with an out flow into the splash well.
I trust all is well with you my friend and hope to see you this summer. Its been a long time.
John
newt posted 02-01-2011 06:57 AM ET (US)     Profile for newt  Send Email to newt
Well good luck with the Kodiak. If you use the bilge pump over the side as apposed to mounting it at the stern, that same pump can double as an aerator if/when you need to travel back up the river and don't want to kill your bait.
Things are good two rivers up the coast. Maybe I'll run into you down at Crane's or out on the ledge this year.
weekendwarrior posted 02-01-2011 07:51 AM ET (US)     Profile for weekendwarrior  Send Email to weekendwarrior
Here is what I did. One of my primary goals was to make it removable for when I am not fishing, I hope this helps:
http://bellsouthpwp.net/m/a/mattsstuff/livewell.htm
adlert posted 02-01-2011 08:26 AM ET (US)     Profile for adlert  Send Email to adlert
Very nice job weekendwarrior. I'm going to remember these ideas.
Newtauk1 posted 02-01-2011 10:43 AM ET (US)     Profile for Newtauk1  Send Email to Newtauk1
Newtauk1 posted 02-01-2011 10:52 AM ET (US)     Profile for Newtauk1  Send Email to Newtauk1
alvispollard posted 02-09-2011 09:03 PM ET (US)     Profile for alvispollard  Send Email to alvispollard
I'm the guy who uses the kodiak 14 gal. tank between the cc and rps. It sets to the left side and the driver sits on it with the rps facing the rear. We keep rain gear, tackle box, pfds,dry boxes, etc. on right side of cc. Fisherman sitting on rps sits on right side opposite pilot. Boat tracks level as a result.
This setup is used when live bait trolling for kings, wahoo, etc. Tank will keep 18 pogies alive and fresh for 6+ hrs. of trolling. Hose from pump is snaked under the left rail. 2' Overflow hose hangs over left side. This setup has worked for 18 yrs. and counting.
I will post some pictures this spring.
Tight lines and safe boating soon,
Alvis
Newtauk1 posted 02-10-2011 02:25 AM ET (US)     Profile for Newtauk1  Send Email to Newtauk1
Thanks-My tank arrived last week. Plan to rig when the snow is gone.
