Topic: 15' Classic wood
Russ 13 |
posted 03-09-2011 01:12 AM ET (US)
I am looking to purchase a 15'Sport. In the "info" section it is stated that the models prior to # 5A0857 only had a small strip of wood under the deck. And models after that had more wood under the deck. As more wood is good, my question is: In what year was this change made on the 15's?? Thanks, Russ
Tohsgib
posted 03-09-2011 09:20 AM ET (US)
I "wood" not worry about it personally. Wood is not necessarily good and unless you plan on making it a center console it is irrelevant. |
Russ 13
posted 03-09-2011 11:54 AM ET (US)
Ahh yes, as that is my intent. I don't like the low side console....as my back is bent. So to install a nice center console, having backing under the deck is important, "wood is good". Does anyone know what year,or month & Year the amount of structure under the deck of the 15' Classic hull changed?? Thanks, Russ |
conch
posted 03-09-2011 12:06 PM ET (US)
In the referance section it indicates Hulls prior to #5A0857 have the narrow wood strip.Check the wood locating diagram it is in a footnote.Chuck |
conch
posted 03-09-2011 12:11 PM ET (US)
Sorry should have read your question more closely, you already know what I posted. If it helps my 1983 has the larger wood. Chuck |
Russ 13
posted 03-09-2011 02:10 PM ET (US)
Yes, it helps to know the 1983 & newer 15's have the larger Wood. Thanks, Russ |
geo15sport
posted 04-24-2011 06:47 PM ET (US)
bought my 15 sport in april of 76 and it's a 0612, hope this helps. |
2manyboats
posted 04-24-2011 09:11 PM ET (US)
My 1977 15 is # 5A1492 |
