Topic: c.1998 Mercury 225-HP EFI Has Very Bad Vibration
mustang7nh |
posted 03-18-2011 06:28 AM ET (US)
I have a 1998 Mercury 225 EFI on my 21 Conquest. The motor vibrates the boat excessively. When you put it in gear the engine itself shakes somewhat, but as you approach 1000 rpm it starts rattling the whole boat through approximately 1500 – 1800 rpm. As you increase the throttle the vibration gets worse. However, once you get above about 1800-2000rpm the boat planes, the engine is smooth as silk. Engine never stalls, starts every time. Loads of power and torque. Once in a while, even during the same outing, it will vibrate a bit less at the same rpm. No pattern as to why, but never is smooth regardless. Engine temp gauge barely moves above Cold no matter what. I get 5400rpm trimmed out and light on fuel. I took it to Mercury dealer and they put the fuel pressure gauge on that fuel regulator and it was fine. He said sometimes they get stuck and run rich. He played with the TPS but really nothing significant came of it. He tried to pull the plug wires off one at a time but shocked himself and decided to abandon that line of troubleshooting. Here is my question: What is actually happening in the combustion cycle to make it vibrate so much and how is this engine designed in terms of its fuzzy logic to adjust itself for smooth operation? My buddy thinks it is running uneven fuel/air mixtures between the cylinders and some are firing harder than on others which is making it shake. He thinks there are four diaphragm pumps that attach to runners on each side of the intake that could be leaking or the injector o-rings are leaking air. At high speed it isn’t mattering as much. At low speed its messing with the air/fuel ratio. Any theories or advice is appreciated.
leadsled
posted 03-18-2011 07:18 AM ET (US)
Is there any chance the prop has taken a hit (bent and not noticeable). |
adlert
posted 03-18-2011 07:52 AM ET (US)
Hopefully a Merc pro like Sosmerc will chime in soon. There's no replacement for advice from someone with a lot of knowledge and product-specific experience.Until then, I would recommend you do what most good mechanics would and that is check the basics to start with just to make sure it isn't something less complicated to diagnose than failed parts within the FI system. Often, it isn't. There is a tendency I've noticed for people to immediately jump to suspect FI problems on an FI equipped engine. This is a mistake. Most outboard FI systems have proven to be very reliable. Mercury's FI systems are no exception. There are many things you can do and should do first that are free (if you are mechanically inclined) or cheap even if you have to hire someone: If there is any downloadable data, do it (I honestly don't think so but don't know for sure with that particular engine). Ensure that you are feeding the engine good, water-free fuel. Give the engine a THOROUGH visual inspection in an attempt to find loose connections, broken wires, out of place links, disconnected hoses, etc. Take your time with your visual inspection! It's free. Put your hands on everything you can reach. While maintaing pressure via the primer bulb, continue your inspection and look for any leaks in the fuel system. Use a flashlight if necessary. Check to see that your propeller shaft is true and that your propeller is true. Check to see that your engine is securely mounted to the boat transom. Try to twist, push, pull on the engine (engine not running of course) to see if you've got any obviously broken engine mounts. The engine should move only slightly, if at all. Warm up the engine and then check engine cylinder compression and also spark quality. Carefully inspect the plugs as you pull them out to look for clues as to differences between cylinder running qualities. Tap plugs into the palm of your hand to check for evidence of water leaking into a combustion chamber. After all that, if nothing jumps out at you, I would proceed with attempting to isolate which (if any) particular cylinders are behaving differently than the others. Removing plug wires one at a time at idle can sometimes help but on 2 stroke V6's it's a bit difficult to tell differences sometimes. Removing one at a time, starting, and then running up through the shaking range may offer some clues. |
adlert
posted 03-18-2011 07:59 AM ET (US)
Another memory just came to my brain. I remember working on a large FI V6 Merc once with very similar running characteristics as you describe. I remember how critical it was to precisely set the throttle pickup timing, idle speed and TPS. One adjustment would constantly affect the other and the process of dialing them all in perfectly took me a good 1/2 hour on the water. But, once done and set to exactly what the shop manual dictated, what a difference!Still, I recommend starting with the items I listed above. No adjustments will fix those things. |
adlert
posted 03-18-2011 08:11 AM ET (US)
And another thing...It would be helpful to know if your engine really is running cold or if that is just a false reading. After you've run enough to warm it up, turn it off and check it manually. Ideally you'd use a temperature stick. Secondarily, you can just feel the cylinder head in a couple of places. It should be quite warm, maybe even to warm to touch for more than a second or two.I think the water tell-tale on that engine may come after (downstream of) the engine thermostats. If so, it is also an excellent source of info for engine temp. You can tell if you have this set-up as you won't get a water pump tell-tale stream when starting up cold for a few minutes until the t-stats open. |
deepwater
posted 03-18-2011 08:52 AM ET (US)
As with all engine that burn fuel its the timing that produces the best results,,If its wrong lots of things go wrong,,Like fuel at the wrong time or no fuel or no air spark early or late and smooth combustion does not happen and the pistons get slammed at the wrong time causing heavy vibrations,,Firing too early while the piston is coming up will jerk the motor hard and firing late makes a weak push down or a backfire,,Heavy vibrations ,,Something is bent or loose |
posted 03-18-2011 09:22 AM ET (US)
I don't think you will find anything as sophisticated as fuzzy logic algorithms in a 1998 Mercury 225 EFI fuel injection control system.Boat vibration results from the complex environment of the engine, the elastic isolators in the engine mount, the propeller, and the boat being mechanically coupled together. You may have a combination of all of those elements that is causing the vibration to be amplified by a resonance. Try changing the propeller to one with a different number of blades. This should move the propeller vibration to a different frequency. The engine speed range of 1,500 to 2,000-RPM for many boat-engine combinations is often a transition to planing from displacement. The engine works hard in this transition, and it may be laboring. It is best to give the engine plenty of throttle advance to get through this engine speed range as fast as possible. If you restrict the throttle advance and keep the engine in this speed range, the engine may run roughly and stumble due to the heavy load on it. I don't know the technical explanation for effects of a heavy load on the engine's combustion cycle, but typical effects when an engine is trying to accelerate with a heavy load and lacks the torque to increase its speed are for the engine to stumble or miss, and for the exhaust to become sooty. To reduce the load under acceleration for an engine, reduce the propeller pitch. If you feed like the propeller pitch is proper, try venting the propeller hub. If you have a Mercury propeller it may already have holes fabricated in the hub for venting; replace the plastic plugs with vented plugs. The heavy load during acceleration onto plane will reveal any weakness in the engine, and the vibrations you are experiencing may be due to a problem in the engine. From your narrative, I would not characterize your present mechanic as particularly skillful. When was the last time you changed the spark plugs on the engine? |
posted 03-18-2011 09:24 AM ET (US)
If the engine temperature never reaches 140-degrees-F while operating at low speeds, you have a cooling problem. The cooling system should be regulating the engine temperature so that the powerhead temperature will warm up to operating temperature of 140-degrees-F after just a few minutes of operation. If you engine never reaches operating temperature, it may run roughly, particularly when trying to accelerate under a heavy load. |
Jerry Townsend
posted 03-18-2011 10:41 AM ET (US)
Mustang - I suspect the problem might be in the engine mount to the boat - and specifically a mount that is too hard via age or just too rigid. The natural frequency of the engine/mount system is probably in the engine rpm of 1500 - 1800 which allows the engine vibration to be transmitted to the boat. The isolation mount is intended to support the engine - and to isolate the boat from the engine vibration.Of course, the engine could be "running rough" with a cylinder not firing or mis-firing. In this case, I will selectively short each plug - by using an ice-pick with a wire temporarily connected to the shaft. Connect the free end of the wire to an engine ground - and then selectively push the ice-pick into each spark plug wire or spark plug boot. If the engine rpm/motion does not change - that cylinder is not firing. This eliminates the shock, but some might object to this technique as it does make a hole, albeit very small, in the spark-plug wire. In a sealed enclosure, this should not cause a problem. --- Jerry/Idaho |
mustang7nh
posted 03-19-2011 06:07 AM ET (US)
Thanks for all advice. Just a point of clarification. Engine does not lack power coming up through the rpm. The vibration is there at those rpm regardless of how fast I advance the throttle. Albeit for a very brief period of time if one where to floor it. Boat leaps on plane with no issues. I realize this may not be the correct analogy for the design of this motor but its almost like it vibrates until the secondaries kick in. Moreover, while its less than silky smooth at say 900 rpm, the real vibration that says I've got to get this fixed is between 1000 and when it planes or approximately 1800. Because the boat transitions from displacement to planing in the 1400 to 1800 range, I can't say I spend alot of time there to give the exact point where vibration stops. I'm also going to split hairs here and report that when you come off of plane to an approximately 1100 rpm throttle setting it seems to be somewhat vibration free for a second or two until everything catches up. But I admit, I have not concluded this under strict testing conditions. Its merely anecdotal. My only thought on the shaft/prop balance issue is that I would suspect the vibration would get worse with speed and not stop all of sudden at about 1800 rpm. Wouldn't it be shaking like crazy at 5400 rpm? I appreciate folks taking the time to chime in. |
mustang7nh
posted 03-19-2011 06:11 AM ET (US)
I will attempt to get some temperature readings on the cylinder heads and also the tell tale water temp as well. |
mustang7nh
posted 03-19-2011 06:17 AM ET (US)
Two more characteristics that may or may not be related. First, when you trim the engine while cruising the voltage gauge needle drops considerably and at planing speeds you can actually hear the engine harmonics change in pitch. Sound gets lower. Everything goes back to normal once you take your finger off the trim button. Trim tab motors have no affect, just engine power trim and tilt.Last, when I winterized the engine, literally as I turned it off for the winter a black serpentine belt broke and came out from under that black plastic cover over the fly wheel. I will get that fixed of course before launch. Thanks again |
Bella con23
posted 03-19-2011 08:16 AM ET (US)
mustang7nh - Sounds like my 1999 23 Conquest w/Mercury 225 EFI to the "T". I have a about a one mile No Wake zone back and forth to the harbor. I am always pushing it to the point where the boat is not plowing deep but no idling either.At this speed the engine is turning anywhere between 1,500 and 2,000 RPMs depending on traffic. There is a fairly heavy vibration in this range and I work the RPM around it as well. This boat and motor combination like others I have been on are similar in that they share the distinct Mercury V6 vibration in this range. Mine rattles everything from the outboard to the pulpit at certain RPM's. I have own this boat for four years and was a passenger on the boat for two years prior and it hasn't changed. The engine is very smooth and responsive otherwise. I should also mention that this Mercury 225 received the best of care including several visits from a Mercury technician on several occasions while in the hands of the previous owner. The trim motor on the Mercury 225 EFI is nothing short of a small engine starter motor. It will have a significant current draw while operating the hydraulic tilt and trim pump. This current draw is much greater trimming the outboard out (away from the boat) and compared to trimming the outboard in. This current draw will place a load on the engine alternator and reduce the RPM by 50 to 100 depending on the running speed at that time. As for the trim tab pump, that pump motor can be compared to a automotive heater blower motor. It will draw much less current and is not nearly as noticeable when operating in either direction. I hope you enjoy what seems to me like a perfectly normally operating 23 Conquest. Joe
Salmon Tub
posted 03-19-2011 02:33 PM ET (US)
Well, this situation is not unique. I had/have the same problem. I have gotten rid of it, sometimes I bring it back. I don't know how simple a fix it would be on an EFI. For me, I have a carbureted 90hp Nissan 2-stroke. Most all outboard carbs (except for <4hp) are basically designed the same with a low speed jet (pilot) and a high speed jet. From idle up to 1200+/- rpm, the pilot jet is the sole supplier of gasoline into the carb's throat. From 1800+/- rpm, the main jet has completely taken over. Between the two ranges is where most outboards produce this vibration because in this range, both systems are partially operating. How it works; Except for DFI, all other systems still ultimately deliver fuel to the cylinder via vacuum. Your crank case creates vacuum as the piston rises in the cylinder. This vacuum acts upon the reed valves, which allow air/fuel in, but now create a vacuum up stream of the valves which sucks air through the only available opening, the carb throat. Here is where the problem occurs. At idle, the carb butterfly is open just a crack. There is an air bleeder (hole) on the butterfly but just ahead of and just below the butterfly leading edge is a series of holes that create a passage called the pilot (Picture a hwy overpass with an off-ramp/on-ramp where there is a road block on the overpass and traffic gets by via the off/on-ramp. With the butterfly closed, vacuum draws air in via the pilot system exit hole, which varies in size based on the position of the pilot screw (mixture). Open the mixture screw and there is more vacuum in the bypass, close the screw and there is less vacuum, since the screw basically acts as a valve. In the pilot bypass, there is a passage that goes down (vertical) into the carb bowl. In the bowl, the passage ends with the pilot jet and vacuum inside the pilot system siphons gas through the pilot jet, up the passage (against gravity) and into the pilot bypass. On the upstream side of the bypass, there is a series of holes (air inlet) that allow air in. As the throttle is advanced, the butterfly edge sequentially passes over these holes, they transition from being upstream to downstream of the leading edge and thus once the edge has passed over all the holes, there is no longer a pressure difference between the two sides of the pilot bypass and it essentially cuts out. At this point the butterfly is open enough that the air is sucking gas in via the main nozzle. Based on the above, you can see that the "mixture" does not control the amount of gas relative to air, but the amount of ail/gas mix relative to air. Secondly, as the inlet holes are closed off one at a time by the advancing butterfly edge, but vacuum remains constant via the mixture screw opening, this forces additional gas via the pilot jet to compensate for the diminished amount of available air. At this point, the mixture going into the bypass has become relatively rich, which is good for proper acceleration. But, if you "cruise" for any period of time longer than a few seconds at this position, the mixture is too rich for smooth operation. Unfortunately, in the case of most carbed outboards, this is in this 1200-1800 rpm range, and unfortunately, this is also the range at which most motors operate in the dreaded "5 MPH Zone". The pilot system was designed to allow for an engine to have the ability to achieve a smooth idle speed at which the engine could operate as well as allow a separate system to take over at higher speed/load requirements. If you had an automobile carb form the 50's/60's (pre EPA) this is basically how they were designed. This system is designed so that the standard operating procedure is to accelerate through the transitional range rather than operate in it. As is, much engineering and testing has gone into the design of these pilot systems to make them as smooth as possible, the remaining flaws are just the nature of the beast. I have been able to get rid of most of my vibration by adjusting the pilot screws to run rather lean at idle since this is the most forgiving speed range, but I constantly monitor my spark plugs for color and deposits. With an EFI system, the amount of fuel/mix is regulated by the ECM so it is impossible to manually adjust. On the flipside, the above might at least point you in the right direction and avoid undue exploratory mechanic's bills.
posted 03-20-2011 08:24 AM ET (US)
If my memory is correct, I believe that L H G has similar engines, Mercury 200-HP 2.5-liter V6 EFI engines from the 1990's. Again, if my memory is correct, I believe the engine mounts on L H G's engines have deteriorated on both engines and required replacement. While two engines is a very small sample population from which to make any sort of general conclusion about these Mercury engines, the failure of the engine mounts is very likely to be associated with excessive vibration and shaking of the engines.I don't know the precise details of the failure of the engine mounts on L H G's engines, but I suspect that the elastic or rubber engine mounting components probably needed replacement. The engine continues to be operable even with the deteriorated engine mounts, and, due to the significant expense, I believe L H G was just living with the problem. The last time I spoke to him about this problem he had not had the required repairs performed on the engines. To repair the engine mounts would require removal of the powerhead, in most cases, so that the elastic or rubber components could be replaced in the engine midsection. Removal of the powerhead on an older engine, particularly one which has accumulated a lot of operating time in saltwater, can be a difficult task. The steel fasteners used to bind the powerhead to the midsection are threaded into aluminum components, and corrosion can make removal of the fasteners difficult. |
mustang7nh
posted 03-21-2011 10:12 AM ET (US)
Thanks for all the assistance. Are these small pilot holes that you describe able to be cleaned? Do they get clogged or does the ethanol do a good job of cleaning everything anyway? As great as the motor is outside this operating range, I can not believe it was like this out of the crate. No one would take delivery of their new boat. I will conceded that there may be the net sum effect of wear over more than a decade that makes this situation practically impossible to remedy. I just want to believe that there a part somewhere that needs replacing and it will run smoother. |
Salmon Tub
posted 03-21-2011 10:54 AM ET (US)
The problem is not that they get dirty. The biggest problem on multi carbed outboards is imperfect synchronisation. A good mechanic will have an "ear" for what the motor should sound like when synced perfectly. The butterflys have to be open/closed exactly the same in order for each of the cylinder(s) to get the exact same fuel/air at idle. As the butterly opens it becomes far less critical since the difference in the size of the openings becomes proportionately less significant. Again, if your system is an EFI 2-stroke, then the amount of fuel introduced into the throttle body is regulated by an ECM and I am not sure if those are adjustable mechanically (air regulation) or via software. Maybe there is a partial blockage of one of the air passages, causing a rich condition. EFI air intake systems usually have a "butterfly" like devise that regulates/restricts airflow. Perhaps the linkage for that is out of spec. |
posted 03-21-2011 07:39 PM ET (US)
I would expect that in an engine with EFI but with multiple throttle plates there would still be a need to have proper synchronization of the throttle plate movement, or what is often called a "synch and link" (as in synchronization and linkage) adjustment. Do you have the OEM service manual for this engine? Typically the OEM service manual will have a procedure for adjusting the throttle plate linkage and making sure it is properly synchronized. Be warned: such a procedure can be elaborate and tedious to perform. |
mustang7nh
posted 04-21-2011 06:07 PM ET (US)
I wanted to add some info. So far the head temperature running it on a garden hose will not go above 78 degrees F. Which according to the mechanic is quite cold and would explain rough running. He says for a race motor that wouldn't be a problem but for recreational purposes there may be an over cooling issue and explain why the gauge never goes above "C" (cold) when I run the boat. |
posted 04-22-2011 09:24 AM ET (US)
I suggest you check the operation of the cooling system. Typically the cooling system flow is regulated by two mechanisms which act to maintain the temperature of the power head in a proper heat range.Cooling water flow is controlled by a temperature sensitive valve or thermostat valve. These often fail due to accumulation of salts or from corrosion. Cooling water flow is also controlled by a pressure sensitive valve or poppet valve, and these are also know to fail from the same causes. |
mustang7nh
posted 06-11-2011 12:22 PM ET (US)
I just wanted to follow up for posterity. New [thermostats were installed,] (although last year I also put in new ones. We changed out the spring on the poppet valve for a heavier spring which would restrict cooling water flow at lower speeds. The engine heads were 122°F on the hose so there was an immediate difference. Temperature gauge actually got off of the "C". After launching the boat and allowing it to warm up, the difference was dramatic. I can not say [the engine running characteristic with regard to vibration] is perfect, as there is some vibration above 1,000-RPM and below 1,800-RPM, but not so much [vibration] that I can not attribute [the cause as being natural for] to a 13-year-old two-cycle engine. In the future, I would not mind trying an even beefier spring [in the pressure regulation valve for the cooling system] in hopes of getting [the engine temperature at lower engine speeds to become] a touch warmer and seeing if that makes a difference. Regardless, the situation is much more tolerable. [Problem] is resolved. |
posted 06-11-2011 03:06 PM ET (US)
Thank you for the follow-up on the resolution of the vibration problem with your Mercury 225-HP EFI outboard engine, and letting us know that altering the cooling system design resulted in higher engine temperatures and less vibration.Were the springs which you used to alter the poppet valve a normal service part available from Mercury Marine? Perhaps you could mention the source of the springs you used to change the characteristics of the poppet valves. I believe that by increasing the spring stiffness you increased the water pressure which must exist in the cooling system before the poppet valve opens and permits more cooling water flow. This should tend to drive the engine temperature higher at lower throttle settings where the pressure in the cooling system is not enough to open the poppet valve. |
mustang7nh
posted 06-17-2011 07:00 AM ET (US)
You are correct in your analysis. The spring was ordered via Mercury parts. I asked about an even higher spring rate, and was told by my mechanic that they didn't make one OEM; hence, trial and error would be needed. Not worth the time and effort on my end to worry about heating the motor up too much in search of that fine line. |
