posted 03-22-2011 11:46 PM ET (US)
Welcome to the PNW, sorry for the crappy Spring weather. It's been below average this year. -- I advise buying a lot of pink salmon gear now, PNW is going to have a good run this year. (Smart move on the electric, I love mine, and always look for deals on used ones.)For the short term I would clamp to the aft grab rails. Wait until you get out on the water and have had your lines down for a bit before drilling holes. -- Holes are hard to undo. -- (And make sure to install a brace to keep the downrigger boom from rolling over due to load.)
(You imply you'll fish solo more often than not correct?)
For the long term, I would suggest the aft corners. But I can't make comments on mounting, but it should be sturdy, you'll be fishing deep at times.
Here are my $0.02:
1. The layout of the boat really dictates what you can (or can not do). But ideally you should be able to sit at the helm to steer (sideways or aft facing most often) and have the tip of the pole/rod in your sight-line. You are fishing after all. - For conventional boats this means helm to Stbd, and the solo rod is to Port. On a center console this is a moot point, but your layout may differ.
2. Most people mount their downriggers far enough aft that when making a turn the lines clear the transom and whatever else is back there. You can overcome this by extending the boom, but the extra length can be awkward at times. (On my boats, the riggers are aft quarters, but forward enough on the gunnels that I can stand further aft than the downrigger base itself, or about 1.5'-2.5' forward of the transom.) -- The overall elementary problem is keep the wire and line from rubbing/touching anything while you fish. (Not rocket science.)
3. You'll likely want a kicker sooner or later. The 16' and 16'7" hull prop torque causes noticeable list to port while underway (you likely know this). Hence, kickers almost always ends up on Stbd. --- With the kicker to Stbd, I always fish solo to Port. Mainly, to stay away from the prop (guard) and to distribute the weight better when you fish opposite the kicker
4. Anticipate how you are going to retrieve the weight and stow/rotate your downrigger when not in use. Mine swivel 360, and I can grab/drop the ball fore or aft of the base. -- Once you get in the water this will make a lot more sense.
