ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Repairs/Mods 2004 Mercury TRIM Motor Failure From Corrosion
Author | Topic: 2004 Mercury TRIM Motor Failure From Corrosion |
froberts |
posted 08-08-2011 10:07 PM ET (US)
The motor for TRIM [on a 2004 Mercury 90-HP outboard motor] rusted thru last week and started leaking oil. [I] removed the motor assembly and called a Mercury dealer; they gave me a price of $480. An Arco-brand pump for the motor cost $150. Has anyone tried the Arco-brand pump? Had good luck? Please reply. Arco says they are made in the USA. [I] don't want to go cheap and regret, but $330 is a lot of money. I boat in saltwater. frazier |
posted 08-10-2011 08:35 AM ET (US)
If the Arco-brand part is a direct replacement, it sounds like it would be worth trying. The $330 difference in cost between the OEM and the Arco replacement is a significant savings. Based on the breadth and width of the replacement trim motors that Arco manufacturers, they appear to have some familiarity with replacement trim motors for outboard engines. http://www.arcomarine.com/xhtml/ Cross%20Reference%20Tilt%20Trim%20Motors.html |
posted 08-10-2011 09:28 PM ET (US)
[The duplicate thread started on this same topic has been deleted. Please do not start two threads on the same topic. Thank you. --jimh] |
contender |
posted 08-10-2011 10:02 PM ET (US)
Jim is correct, why spend the extra coin for the same thing, I can not believe [the Mercury TRIM motor] only lasted this long. Spray the new pump with some LPS-3 before you put it back on. |
martyn1075 |
posted 08-10-2011 11:33 PM ET (US)
Is the Acro brand pump a third party part? Does Mercury offer there version of it or is strictly a third party part that is used in Mercury engines. Thanks, Martyn |
Tohsgib |
posted 08-11-2011 11:29 AM ET (US)
ARCO is a great pump, probably better than OEM. |
newt |
posted 08-11-2011 03:02 PM ET (US)
It [is] hard to imagine anything worse than OEM if the OEM pump rusted out enough to leak oil after 6 to 7 years! |
outragesteve |
posted 08-11-2011 03:52 PM ET (US)
I use Arco products on repair jobs all the time. Great products, service, technology, and cost. |
martyn1075 |
posted 08-12-2011 12:00 AM ET (US)
I would go with the [Arco-brand replacement part]. I really do believe Mercury has a problem with these [TRIM motors]. It [is] hard to prove, but I have had [Mercury TRIM motors] fail prematurely twice on different engines in the same year! The other owner had one changed out under warranty. I was told corrosion due to a bad ground a few slips down in the marina was to blame. I also heard a lack of zinc protection as well could cause it. Ahh, I don't know about that, but [TRIM motors] shouldn't go in only a few years. After reading Frazier's post I think there may be something wrong with the OEM part. |
froberts |
posted 08-13-2011 04:51 PM ET (US)
I [installed] an ARCO pump today and it works great. It was an easy job and the pump looked really nice. Plus, I saved a lot of money. Thanks for the responses.--Frazier |
