posted 08-22-2011 06:27 PM ET (US)
No shims that I recall but there are several(3) thrust washers.This should be easy,use the impact tool and maybe some heat.
All the seals are in a kit online at IBoats for about 15 dollars.
Notice that the pivot pin (philips head screw in skeg)has its own seal
Parts diagrams are online at boats.net
I use a liquid brush-on sealant for the spaghetti seal and the mating surfaces.
If the clutch dog or cradle are worn they can be reversed which puts the worn side towards reverse gear which is used less often and at lower speed.
Take care not to lose the small dowel locating pin at the gear case head seal.
Usually it is just the seal at the prop shaft torn from fishing line.
