ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Repairs/Mods Renovating Outboard Motor That Has Not Run for 15-years
Author | Topic: Renovating Outboard Motor That Has Not Run for 15-years |
speckulizer |
posted 11-15-2011 10:13 AM ET (US)
Hi guys. Let me start by saying that I have read quite a bit of great posts on here, but I still have some unanswered questions. I recently purchased a 13-foot Whaler with a 1981 35-HP Evinrude. The engine was once wired to this boat, but is now disconnected and just has wires hanging from it. According to the seller, the motor has not been run in [over] 15 years. From what I have read, the first thing I need to do is check for compression. Please correct me if I am wrong. Unfortunately, many of the posts that I read seem to pertain to an engine that has recently run, or is currently wired and installed to a boat. Please bear with my questions because I have only done some very basic maintanance with outboard motors. Is there something that you would do before doing a compression test to a motor that has been sitting for over 15 years? How do I get the engine to crank with all of my ignition wires undone? Or if I go straight to the starter, what do I do with the ignition wires? Do I need to run fuel to the engine for a compression test? Should I be worried to crank the engine if it has not run in 15 years? I fear that I may break something else Do I sound so clueless that I am in over my head? Here is a [url] to some pictures of the motor: http://s1129.photobucket.com/albums/m509/speckulizer/. Let me know if you would like to see other images to help. Thanks in advance--PK |
Tom W Clark |
posted 11-15-2011 11:02 AM ET (US)
Whoa there Parker! You need the get the motor running first before you even consider doing a compression tests. First things first. If the motor doesn't run, the compression is irrelevant. If you gave not yet turned the flywheel (and I hope you haven't) then remove the spark plugs and get some oil in the cylinders so that when you gently move the flywheel the cylinders will have some lubrication the first tim the pistons start scraping on the cylinder walls. Once you done this and the flywheel turns freely you can try to start the motor. The carburetor may, or may not, be gummed up and need a rebuild but trying to get it to start is not going to harm it at this time. I;d try the getting it running before I invested the time to take the carburetor off and take it all apart. If you are going to run it in a barrel of water you can us the ends of the wires to start the motor. You need to identify what each one is and this Reference Article will help: http://continuouswave.com/whaler/reference/ignitionSwitch.html |
Tohsgib |
posted 11-15-2011 12:27 PM ET (US)
With a twin you really don't need to do a compression test just yet. Put a tad bit of lubricant in the cyls and reinstall the plugs. Turn over SLOWLY by hand using the flywheel. You will feel it build compression and then lose it and do the same thing again. If it feels the same the second time around then both cyls have compression. You can do this also by removing the plugs and sticking your pinky in the hole, it should try and blow out your finger. |
speckulizer |
posted 11-15-2011 12:29 PM ET (US)
Haha thanks Tom! As you can see, I don't really have a clue what I am doing. With that said, I am trying to learn from people like you and through the power of google (taken with caution). What type of oil would you recommend for lubricating the cylinders? |
Tohsgib |
posted 11-15-2011 01:20 PM ET (US)
Anything...wd40, PB blaster, a few drops of 2 stroke oil. |
Binkster |
posted 11-15-2011 02:30 PM ET (US)
Follow tohsgibs advice on pre lubing the engine. No need to get it running first before checking the compression. A compression check should be done to see if it is even worth trying to start it. If the compression is normal and each cylinder is within ten percent of the other(s) then the engine is worth doing what you need to do to make it run. If you get spark to the starter and a ground, the starter will engage the flywheel and the engine will turn over. squirt some penetrating oil in the starter bendix, as it may be stuck from sitting. If the compression checks out OK, then check for spark through the ignition system and fuel into and through the carbs. Also check that the engine is pumping water if and when it starts. If the compression is bad in both or one cylinder you now have a parts only motor. After it is run for a while check the compression again. It generally will be higher as the rings loosen up. Now its time to decarbonize the motor. That's been covered on other threads, look it up. |
contender |
posted 11-15-2011 04:21 PM ET (US)
Wait stop do not start the engine....I would 1st change the water pump, over a time of sitting that long and not moving the rubber will crack and just break in the housing. I would use some Marvel Mystery Oil (lubricates and protects the rings) in the cylinders and turn them over by hand, The carb needs to be rebuilt and blow out the gas line, and some new plugs to help start the engine...good luck...Ps you start the engine and the water pump breaks you will over heat the engine, and then it will be trash... |
Tom W Clark |
posted 11-15-2011 10:20 PM ET (US)
No, get the motor started first. There is no reason to invest a bunch of time and money into a motor that will not run. You need to see if it is viable before rebuilding the carb and replacing the water pump and all the other maintenance stuff you should do. *If* you can get it started, make sure it is pumping water. You'll have several minutes to verify the water pump is moving water before it overheats. The tell tale should be passing water and you may want to insert a length of heavy monofilament or line-trimmer line into the tell tale to make sure it is not clogged (a very common problem). An infrared thermometer is a useful tool to tell if the powerhead is getting too hot. They are inexpensive now and I keep one around the house for a variety of tasks. Prioritize. A motor like this running well is only worth $400-$800 so don't go out and buy a bunch of new parts for it before you verify it runs. If and when you get it running and determine it is viable then yes, by all means, replace the water pump impeller and rebuild the carburetor as well as change the gearcase lube and grease all the grease points. |
djacksonrn |
posted 11-16-2011 07:47 AM ET (US)
Sorry to plug another site, but Iboats.com has a great article under the OMC forum sticky called "awakening a sleeping outboard" or something similar. It gives step by step instructions on the process. There are answers to every question you've asked in that specific forum. |
Binkster |
posted 11-16-2011 10:11 AM ET (US)
(No, get the motor started first. There is no reason to invest a bunch of time and money into a motor that will not run.) That sentence makes no sense at all. I've resurrected a bunch of old motors, and have seen members of the AOMCI do the same. Its part of the fun of the antique outboard hobby. As stated before the most important thing to find out is if the compression is good enough for that outboard to be considered good enough to run normally, unless it is a rare and valuable outboard(yours is not) and you would rebuild it anyway. |
Binkster |
posted 11-16-2011 10:21 AM ET (US)
Also, no need to surf other sites for 'how to do stuff' info for your outboard, or your Whaler. Its all available here, just ask, or search the archives. Hope you make good use of this forum, so stick around, its a fun place to hang out too. |
adlert |
posted 11-16-2011 10:38 AM ET (US)
Just throwing 2 more cents in. I'm solidly with Binkster and Contender here. Do NOT start the motor first. Lube through the spark plug holes and also put the engine on its back (carb throat pointing straight up) and then put lube down the carb throat. Opening up the throttle will help you get more lube down to the reed plate and ready to be sucked into the crankcase. Now gently pull the engine through a few times by hand with the engine still on its back. Add some more lube into the carb and repeat a few times. Now do a compression check! It's easy and easy on the engine. Though it may not be what it will be once you're up and running, it will likely point out huge problems (like very uneven compression) that will great affect the effort expenditure and decision making process. If compression is way off, pull the cylinder head next if you want to keep going and determine just how bad things are. If compression is reasonably good, there's very good cause to keep going with this project. Next thing to do is check for piston slap (I can elaborate on that later, it's easy too) and then for water in the gearcase and spark quality(also easy). If the above all looks look hopeful there is very little reason to believe you don't have a good engine that is likely going to run fine soon for little additional money. BEFORE STARTING, I'd highly recommend you at least inspect and replace the water pump. Then, you'll preferably want to clean the carb. If you do these things the engine will likely fire up and be fine. I recommend this order of events because I have all too many times had customers start a stored engine first, then have over heating problems which become much more than a simply impeller replacement job. This happens when the impeller is so dry rotted that upon first firing, blades immediately crumble and get pushed up in the powerhead where they get lodged in impossible (or very difficult) places to find. The symptoms are then hot spots in the powerhead or perpetual overheating problems even with a new impeller. I've spent DAYS chasing impeller bits down. Often you can never get them all out and return the cooling system back to design specs. |
adlert |
posted 11-16-2011 10:47 AM ET (US)
My apologies to Binkster and Contender for some overlapping info in my post. |
Tom W Clark |
posted 11-16-2011 10:53 AM ET (US)
Tim -- Start reading at the top of the thread next time. |
dg22 |
posted 11-16-2011 11:46 AM ET (US)
I had picked up a 1961 Merc 500 which had not run in years. Like many have advised I put some oil in the cyclinders turned it over and then checked the compression. Just in case you have not used a compression tester, keeping pulling the motor over until the needle stops. I got lucky, the compression was great; 120 on all 4 cylinders. I re-built the fuel pump ($10 or something for kit), I just cleaned the carbs but I agree re-building would be best. I had someone with more experience do the timing ($150) and checked over what I did. The motor ran great and started first pull most of the time. Oh yeah replace gear lube in lower unit and check it over. Anyhow, you don't have to spend a ton if you do what you can do and get help where needed. |
speckulizer |
posted 11-16-2011 01:11 PM ET (US)
Thanks for all the great responses guys. I will post back when I have some results to report. |
adlert |
posted 11-16-2011 01:14 PM ET (US)
I did Tom. I just realized I didn't fully read Binkster's and Contender's last posts. I still highly recommend compression and piston slap checks early on in the process and not starting a 15 year old motor first due the water pump problems I described. |
adlert |
posted 11-16-2011 01:22 PM ET (US)
Furthermore, the "viability" of a motor is not determined by whether or not it currently runs, or how it currently runs. It is determined by many other factors; most importantly the overall condition of the moving mechanical parts (power head and lower unit). Generally, a fairly good guesstamate of these parts can be made on a non-running motor. Certainly, the same techniques must still be used again to re-assess the running motor. |
Tohsgib |
posted 11-16-2011 02:02 PM ET (US)
I agree, if the piston has slap, might not be a good idea to fire it up just yet. It is easy to tell the condition of the rings. |
