PFSQUAN
posted 03-14-2012 02:42 PM ET (US)
Butch: the best way to keep anti-foulant paints from thickening into a gel when a portion has been used is to thoroughly clean the rim so you can seal the lid tightly. Then, pour a tablespoon or two, or more of the recommended thinner, (I think in your case it might #120, but I am not positive, so check your can to be certain)to create a thin layer of the thinner over the paint. Make sure the entire surface is thoroughly covered about 1/4 inch. Don't stir it. This will prevent air in the can from reaching the paint and keep it in good shape. Gently tap the lid tight with a hammer and it will last at least a year. This trick works with all oil-based, one part paints.Be sure to store the can upright so the thinner remains on top.An alternative would be to buy a clean, empty quart can from the paint store, fill it to the brim and seal it tight. On my Tashmoo and Montauk I never needed more than one quart for one coat when I used Interlux Fiberglass Bottomkote. I have also used Pettit Unipoxy, Pettit Hydrocoat (water base), Interlux Micron will excellent results. This year I had the bottom of my Montauk soda blasted and after I patch a few blisters I will be applying Interprotect 2000 and top coat with Interlux Pacifica,a non copper paint, which I also will use on the lower unit and motor bracket. Peter |
