| Author | Topic: Working with Kydex |
| rhysleo |
Is [Kydex] hard to work? How hard is it to form [Kydex] into a simple U-shape with 90-degree angles? Will [Kydex] chip or splinter when cutting with a power saw or jig saw? I want to make a custom storage box under the seat of a 13-foot Boston Whaler boat using [Kydex] because it's light, cheaper than starboard, and it's what was used in the original rear storage compartment in a '985 13 Whaler. |
| David Pendleton |
I've worked with it to make holsters. With a good heat gun, it's easy to form. I've only cut it with shears when it's hot and soft. You could probably cut it okay with a high-speed jigsaw or Dremel-like tool with very fine-toothed blade. That should reduce or eliminate chipping. |
| Jeff |
[Kydex] is very easy to work with. All you need is a heat gun like David said and something good and straight to bend [Kydex] over. Getting [Kydex] is tough due to the minimum quantities your need to order. Getting [Kydex] in the OEM color and pattern is next to impossible do to the larger minimum order quantities. That said, Mike at Nautical Lumber did buy enough to clear a minimum order and is currently making the 13, 15 and 17 underseat pans as well as the Revenge and Outrage under gunwale close out panels. You may be able to have him make you what you need or you my be able to source materiel from him. Nautical Lumber |
| David Pendleton |
You can also try Professional Plastics: http://www.professionalplastics.com/KYDEXTSHEET?&search_id=862555 They have a minimum order dollar amount, but it isn't much. |
| Whalrman |
Is [Kydex] the material that the two side pannels are made of on the classic Outrages that cover the fuel and wire harness? |
I believe Jeff answered your question. See above. |
| rhysleo |
I have to ask. Why is the word 'Kydex' in brackets for each post? |
| Jeff |
Whalrman, Yes Kydex is what the close out panels are made of The instances of [Kydex] are the moderator editing posts to increase the site's searchability. |
| lizard |
Well, you learn something new every day. Kydex jackets are custom molded and fitted 2-piece, jackets, that certain patients have fitted after certain spinal surgeries. I never imagined an application outside of the medical use. |
| Whalrman |
Thanks for the reply and information of the close out pannels. |
