ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Repairs/Mods Polish for Stainless Steel
Author | Topic: Polish for Stainless Steel |
Teak Oil |
posted 03-21-2012 07:23 PM ET (US)
My [boat's] stainless steel rails and other hardware could use some polishing. It is is not rusty, it just needs its luster restored. Should I just use wax or is there a better product? |
posted 03-21-2012 08:42 PM ET (US)
Try BAR KEEPER'S FRIEND to see if it is effective for your situation. |
Jeff |
posted 03-21-2012 08:58 PM ET (US)
I most of the time just use a good wax being that we are in a freshwater area. I also have used had great success with Mother's Aluminum and Metal Polish. It also works great to quickly buff out minor gelcoat scratches. Some like Brasso for polishing. I personally do not care for it, nor do I think is out shines the Mothers product. |
David Pendleton |
posted 03-21-2012 08:59 PM ET (US)
I like Collinite's #850 Metal Wax. It will even remove light scratches. |
macfam |
posted 03-21-2012 09:02 PM ET (US)
Ditto on the Collinite 850 Metal Polish. Great product. |
frauke75 |
posted 03-21-2012 09:35 PM ET (US)
I am sure it is overkill but this detailing tutorial from a vintage BMX site might have some tips for you. The first part covers aluminum so just scroll down to the picture of a bolt. This guy takes an off the shelf stainless bolt and turns it into a mirror. http://www.vintagebmx.com/community/lofiversion/index.php/t4005471.html |
Jeff |
posted 03-21-2012 09:54 PM ET (US)
That is some super nerdy bike geek work in that link. I loved it. Brings back memories. http://www.vintagebmx.com/community/lofiversion/index.php/t4005471.html |
Teak Oil |
posted 03-22-2012 11:59 AM ET (US)
Thanks for the suggestions. Are Bar Keepers Friend and Collinite available at Miejer's or Wal-Mart? |
K Albus |
posted 03-22-2012 12:05 PM ET (US)
Bar Keeper's Friend is available at just about any grocery store. For the Collinite 850 Metal Wax, you'll probably have to go to a boating supply store or an auto parts store. |
posted 03-22-2012 01:30 PM ET (US)
BAR KEEPER'S FRIEND may be too much for your situation. It will remove corrosion. But it will only cost a few dollars to give it a try. ASIDE: Not long ago we were doing a bit of clean-up at work. In the back of a cabinet I found a small bottle of metal polish, dating from the 1960's, that was made by a local company in Detroit. I tried this stuff on some brass electrical plugs--it was fantastic at removing oxidation and leaving a bright polished surface. It was the best metal polish I've ever used on brass. PORTER'S FRIEND North American Polish Corporation Compare at |
andygere |
posted 03-22-2012 01:57 PM ET (US)
The best stuff I have used is Woody Wax. It's expensive, but it works very well to restore the shine, and adds a lasting level of protection to the metal surface. I use it for both stainless and marinium parts. A little goes a long way, and the kit I bought 3 years ago still has some material left. If things are really pitted, this will save you some work. For a quick and dirty clean and shine of stainless steel, sparay some WD-40 on a rag and give it a wipe. Works better than you would expect, and is great for a quick shine when cleaning the boat after an outing. |
litnin |
posted 03-22-2012 02:28 PM ET (US)
Simichrome or Flitz. Both are made in Germany and are available at Harley shops. The best IMO. |
Tohsgib |
posted 03-22-2012 03:17 PM ET (US)
2 things about cleaning metal: 1) Use regualr cheap white vinegar and it will clean the rust off in seconds....seriously. 2) When you polish it you need to put something on it that will protect it afterwards. Woody wax is good for that as it is a spray. Personally not the best color restorer but great for protection and non-skid. I like the "original" blue can never dull personally, polishes and protects in one. Do NOT however use it on anything anodized or gold plated unless you want to screw it up. |
Ridge Runner |
posted 03-22-2012 04:49 PM ET (US)
I have used most products on the market including Flitz. I have found that Starglow Extreme works better than any that I have used in the past. I use it on all types of metal including my SS appliances, guns and even the SS bands on my watches. It's not cheap at ~$35.00 but works great. |
ConB |
posted 03-22-2012 05:31 PM ET (US)
You polish the chromium oxide off the stainless that keeps it from rusting, then you have to put something on the stainless to keep it from rusting. What ever. |
Teak Oil |
posted 03-22-2012 08:22 PM ET (US)
Looking through the boat I found a bottle of Collinite 925 and some Collinite 870. Are these less abrasive than the 850? |
macfam |
posted 03-23-2012 06:15 AM ET (US)
925 has no abrasive at all, and is safe for clear coat automotive finishes. 870 is a cleaner/wax, and may contain mild abrasives. |
MarthaB |
posted 03-25-2012 09:09 AM ET (US)
Suggestion from a magazine, "Real Simple", is use olive oil to polish stainless steel and baby oil for chrome. |
Russ 13 |
posted 03-25-2012 06:38 PM ET (US)
I use 3M Heavy Duty polishing compound, it works great on removing oxidation from gellcoat & painted surfaces (What it was designed for),But it also works great on rusted Stainless Steel! It is available at most automotive paint supply stores & some marine stores. I add some to an old tube sock & just rub on, it does not take much effort to get great results. Then wipe off any excess & apply a good paste wax, let dry & buff off. BOOYAA!! Pass the shades!! |
Teak Oil |
posted 03-25-2012 07:24 PM ET (US)
I am going to try the Collinte 870 first. My SS is only slightly discolored, not rusted, so this should clean it up well. If it doesn't I can always get out the heavy hitters then. Thanks |
Tohsgib |
posted 03-26-2012 01:44 PM ET (US)
Or vinegar. |
elaelap |
posted 03-26-2012 03:12 PM ET (US)
Wash and wipe down with fresh water after every ocean trip. WD-40 every now and then. Very light application with a rag. Waxing the stainless rails...pu-leeeze! Tony |
Russ 13 |
posted 03-26-2012 11:27 PM ET (US)
Well the wax protects & improves the shine! WAX-ON.....WAX-OFF!! Since some of us wax the hull, the railings are no big deal, it's better than having uggly boat syndrome. |
Russ 13 |
posted 03-26-2012 11:31 PM ET (US)
WD-40??? to remove the screws?? Well I WAS inside the boat, untill I grabbed the slick as snott railing. Now I am slime-d & wet. |
Jefecinco |
posted 03-27-2012 06:20 PM ET (US)
I've been using Brasso since 1955. There is nothing better in my rather vast experience. The resulting shine is unmatched. Follow with Woody Wax for a little longevity. Butch |
