posted 05-05-2012 11:04 AM ET (US)
I was talking with a friend about having a camper enclosure fabricated for my boat. He told me that he had two complete camper systems for an older boat he once owned. When he sold the boat, he still had an older one in his basement.I went and checked it out and found it to be in excellent condition. It is complete; has all the stainless steel frames, hardware, and top, side & rear canvas. The canvas is in great shape & the color even matches my existing canvas set. He gave it to me as he had no use for it.
Since the price of the canvas enclosure was right (free) I plan on attempting to modify it to fit my boat. It appears that the height will match the existing canvas, and the side curtains should fit with very little modifications. The only problem is that the boat that this came off had a wider beam than my Revenge; I would have to reduce the width of the stainless steel frames and the top & rear canvas by approximately 15 inches.
I have already spoken with a local canvas shop about reducing the width of the top, and they would be able to do it for short money. They will even modify the zippers on the top & side curtains to allow it to mate up to my exisitng system However they do not work with stainless steel and had no advice on modification.
Is is possible to cut a section out of the frames in order to reduce the width & then join them back together again? I have seen this done with railings, but was unsure if this would work with a top frame. Will I loose too much strength in the frames if there is a joint in the center of the top? Where would I obtain parts or information?
