posted 07-10-2012 09:13 PM ET (US)
I know this has probably been discussed ad nauseam, but I could not find this particular answer...I've got an older 13 footer that I've been readying for the water and I've got a longshaft Merc 40 that I'm planning on hanging off the back. My original plan was to fab something like the Kentfab plate and fill/raise the notch in the transom, but I think something along the lines of the CMC 5" Vertical Extension would be a little cleaner, easier to fab, and easier to install/remove.
Here:
http://cook-mfg.net/cart/index.php?main_page=product_info&cPath=10_13&products_id=13
The engine weighs apprx. #180. My only concern is in the through-bolting of the Vertical Extension tabs. If I choose to make the extensions long enough to reach almost down to the waterline (so to distribute the force of the engine over the largest possible transom area), is it safe to through-bolt the lower ends of the Extensions?
They would no doubt extend down beyond the area that "bumps forward" about 1" in the motorwell (on the interior side of the transom), and therefore I would be drilling and bolting directly through this apprx. 1" thicker area. Is this area solid wood beneath the glass, or is it foam-cored over the uniform thickness of the transom wood?
If so, should I scratch the idea of through-bolting through this lower portion, as it would probably just compress and crack the glass/foam?
Thanks!
