posted 08-02-2012 12:18 PM ET (US)
Wrap Up - She's bolted back together. Initial tests on muffs = Pass. For you hard cores this is probably funny. I've wrenched on lots of stuff, bikes, cars, dialysis machines and the actual assembly is simple to put together but access sucks unless lower cover removed and there was no clear method there.
Here's what went down sharing a few details for those of you who might do this sometime.
Tool list -
- real long needle nose pliers (saved the day)
- 1/4 drive 6 pt socket and flex extension
- 3/8 drive 6 pt flex socket (sourced at NAPA)
- one paint stir stick
- one 1x2" board ~ one foot long, ( should have cut a wedge on the end - would have worked better
- Official Evinrude OMC gasket goo - non hardening, stays sticky. Worth it.
1) There is no question manipulating all components into a subassembly around and under the "bubble back" casting, lining up two thermostats, two poppet valves, two gaskets, three bolt holes all while compressing two poppet springs requires either some weird tool or four hands and two sets of eyes. To that end, while solo I tried tie wrapping things together and wooden wedges per suggestions from the crew out there. Thanks!
2) So, still solo, I practiced dry fitting the assembly a half dozen or more times until I determined best line, left to right, to insert, tip, twist and slide the parts into place.
3) After the first beer, my neighbor (now everyone needs a neighbor like Gary), a retired tool and die man, rolls in to talk Pesto making with Ellen. He moseyed on over and said "you havent' got that thing put together yet?". At which point he said "if this was my boat I'd get my die grinder out and run a simple hole in the center to access that bolt and modify that lower cover so you can get a freakin' wrench in there..." and I said "lets do that right now." and he said - "let's give it a try first, your compressor probably doesn't have enough air to run the die grinder." I said - "okay"
4) I show him what I rehearsed and positioned the bolts, gunked up gaskets and all the parts and were ready to give it a try. I put a chair next to the motor for one of us to have good access and view from below and the other from the top.
5) I had a wooden paint stirrer and a 1X2" board about a foot long to wedge the parts in place once springs were compressed as we inserted the bolts. Thanks Larry - but it would have been even better if we cut a wedge into it per tool maker.
6) So we positioned the springs into the block and used the paint stick inserted from right side to compress and hold the springs in place. We had to use a big screw driver (real big - or socket extension would work) to put pressure on the middle of the stick.
7) We used some Phil Wood bike grease (any grease would work) to make the plastic poppets sticky enough to stay in place and the thermostats seemed fine probably because of some of the gasket compound.
8) Garry held the springs down while I inserted the assembly from the left hand side. This was tricky but going slow it worked fine removing the paint stick a few centimeters at a time. to the right.
9) Once in place (magic) Garry took the 1/2 and wedged the cover in place so we could insert the bolts.
10) using the modified 7/16" wrench (ground down for easier access - I did that with Larry's advice) I slowly turned the RHS bolt by hex head until it was close to the cover.
11) While attempting the same on LHS, Gary grabbed the extremely long needle nose pliers and began turning the RHS bolt a little more by the shaft instead of the hex - that was genius. He did the same on the LHS bolt and a hell of a lot faster than millimeters by the box or open end wrench.
12) once the side bolts were clearly in place (being careful not to tighten at all) I inserted the center bolt and with flex socket, got it in place
13) I went through tightening sequence and after looking around for any parts we forgot to put in - we were done!
14) TRIAL - I hooked up the muffs and fired up the motor, inspected for leaks (had to tighten one clamp) and let her run. Tell Tale was strong ( yep, like pissing over a six foot fence).
As the motor warmed up I used the digital thermometer (just picked up from Harbor Freight for about $38 bucks) and took readings. After about 10 minutes or more the RHS was running around 128-130 F and the LHS was around 122 - 124 F. I let it run probably 15-20 minutes and the readings were about the same.
15) today - heading to the lake a little later .
Thanks so much for all your help. And yes - I'm gonna let Gary loose with his die grinder to modify that bottom cowl. Why not?? There is no structural risk and it makes sense.
