posted 09-25-2012 06:08 PM ET (US)
First of all, please excuse me if I am not using the correct terminology with my questions; I don’t have a lot of knowledge with boat steering systems. I am considering the installation of a Garmin GHP 10 autopilot to compliment a Garmin 4208 chartplotter and radar already installed on ’89 whaler 27 with twin Evinrude 225 FICHT.1) Am I correct to assume all the following constitute an unbalanced steering system: single outboard with one cylinder, twin outboard with one cylinder and a tie bar to second engine, and twin outboard with twin cylinders both mounted in the “same direction”?
2) Am I also correct to assume the following constitutes a balanced system: twin outboards with twin cylinders mounted opposing each other? (I believe this is the setup I am working with)
3) For the purpose of the above described balanced system, how do I determine or calculate the capacity of a balanced twin cylinder steering system? Is it just the fluid capacity at the helm, or do I need to include the capacity of one/both cylinder(s)?
4) Can anyone inform me of the standard steering system likely to be on this ’89 whaler 27 and how to confirm that it is the original and not an updated helm?
I need to correctly identify the installed steering system and determine the total system capacity to determine which pump I will need to purchase. The Garmin GHP10 core pack #010-00705-00 can be paired with a 1.2L pump or a 2.0L pump. Apparently there are some engine hp restrictions also, but at this point a Garmin technician is telling me I need to confirm the helm type and capacity first. Based on all the variables the tech suggests I may need to upgrade to the costlier GHP20, I’m hoping this is not the case as there is $1000 difference between the two units.
