ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Repairs/Mods Drain Tube - 22-25ft Whaler Outrage
Author | Topic: Drain Tube - 22-25ft Whaler Outrage |
scotch |
posted 02-13-2013 06:21 PM ET (US)
Hey Guys, The drain tube in the front hatch eroded in the actual tube below the water line, which was leaking in water in the fiberglass. Need to replace it but was wondering if/where I could get a factory replacement. Any info would be greatly appreciated. Thanks, |
wannabe |
posted 02-13-2013 06:33 PM ET (US)
I believe Sue @ twin cities marine is your best shot. |
L H G |
posted 02-13-2013 07:07 PM ET (US)
If it's a 25, that's a difficult replacement. At least it was for me - so much so that after ruining 3 tubes, I gave up. My guess is that when you get it out, you will find water dripping out of the surrounding foam. Let it dry for a week or so (assuming the boat is on a trailer). The reason it is a difficult repair, once you get the old one out, is that the inside and outside surface are not parallel, and exit the hull on an angle slice. This makes use of the crimping tool almost impossible. You will also probably need a repalcement Perko drain cover, which needs additional holes drilled in it. I brought my boat to Twin Cities for the repair, who has a special tool needed to do this, and which lasted about 6 years. I just had it re-done this past summer. |
Tom W Clark |
posted 02-13-2013 07:12 PM ET (US)
Just make you own. It is a simple repair. I've done dozens of drain tube replacements, including all the drain tubes in my own Revenge 25. This thread offers some good instruction and detail: |
posted 02-14-2013 09:14 AM ET (US)
Replacement of drain tubes is covered in the FAQ. Q12: How Are Drain Tubes Replaced? |
FC |
posted 02-18-2013 05:16 PM ET (US)
I see your in San Diego, I have the tool for the replacement if you want to use it. |
