ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Repairs/Mods Montauk Console location
Author | Topic: Montauk Console location |
hullinthewater |
posted 07-05-2013 04:10 PM ET (US)
I'm in the process of converting my '87 SuperSport to a Montauk clone. As such, I'm planning an install of a non Whaler console [heresy, I know] of approximately similar dimension. The console I'm considering is about 24 wide x 33 long, with a forward seat-storage bin. [See 'Niente' model at this page: http://www.boatconsolesandbaitwells.com/index.html] Thus, I'm looking for info on the original console location, relative to the transom, or back of anchor locker. I recently took a picture of an original Montauk of about the same year, but didn't have a tape to measure at the time to check console position [nor would I want to be reaching someone else's boat w/out their permission]. Can anyone confirm this, or share a link that contains original layout form transom or anchor locker. |
sdfish |
posted 07-09-2013 01:36 PM ET (US)
I'm interested in a response to this as well. Thanks |
hullinthewater |
posted 07-10-2013 10:58 AM ET (US)
I think the lack of responses might be due to the infrequency of the problem: not many people have reason to make a console replacement or relocation. As I stated, mine was a SuperSport, but I don't like the 'shin-banger' nature of the low profile mahogany setup- it's especially not good for fishing, or much else beside sitting in a low position, and if you have long legs, you will get cramped. So I'm replacing the mahogany [wood maintenance: retired yet?] with a combination console/seat with a hinged forward storage/seat locker. The critical thing will be positioning the console for best weight distribution of 2 adults at helm, and with minumum bend in routing steering/control cable thru the forward sump. Can't remember if it was here or whalercentral where a member posted dimensions from transom to back of console, back of seat, etc. Can't find it here, but I might try different search terms. |
sdfish |
posted 07-10-2013 06:56 PM ET (US)
Hull - let me know where you land, I conveted a super sport to a center console a few years ago. THe console I used had a smaller footprint. I just sourced a BW 170 center console that I will install and would like know the factory location as well. When I mock measured the new console, I came to the same conclusion you did below on location. Thanks |
Qtrmeg |
posted 07-11-2013 07:58 AM ET (US)
Is this what you want?
sdfish |
posted 07-11-2013 01:06 PM ET (US)
Yes that helps for sure. Can you also provide the measurement from the from the from of the console. Also, what year and model is the graphic from and which boat are measuring from? i Have a 1984 17 foot hull. Thanks again! |
jcdawg83 |
posted 07-12-2013 08:37 AM ET (US)
I don't really have any info to help, but I do have a question. Is there a tunnel in the center of the hull to run cables to the engine and the fuel line from an under seat tank? If not, I would think it would be better to sell the 17 SS and simply buy an older Montauk. |
Qtrmeg |
posted 07-12-2013 09:19 AM ET (US)
jcdawg83, the rigging tunnel is there, just glassed over. sdfish, my Montauk is Smirkless and one hour away, these two threads I will link you to are for the Smirked Montauk, like yours >>> http://www.whalercentral.com/forum/viewthread.php?thread_id=1412 |
sdfish |
posted 07-12-2013 10:03 AM ET (US)
Q - thanks for posting that link. It is just what I was looking for. Switching out the console will be next winters project for me. JC - yes, my 1984 has a tunnel in the center to run cables. The current hole in my boat runs from the location of the center console to the sum in the rear. The supers sport model does not have an access hole in the location of where the Montauk RPS would be to run fuel lins. I will have to open up a hole there to run my fuel line. Thanks! |
hullinthewater |
posted 07-12-2013 11:47 AM ET (US)
Lots of input all of a sudden. As I posted originally, my hull is [was] a 1987 SuperSport w/Mahogany lo-console setup and it has the rigging tunnel and fore and aft sumps, understandably and like sdfish, I have no 'hawse-hole' where a Montauk RPS seat would be for fuel line route. Regarding the provided link to the "Plan view", if I'm not mistaken, that looks more like a Montauk 170; whether they're identical in "console to stern" dimension, I'm not sure. sdfish, part of my original query has been recently answered by a posted pic on WhalerCentral of a memeber Montauk resto. It was a cockpit deck view that showed the back "feet" of the console positioned about even with the beginning of those famous little side ramps on our "pre-170/post '76" decks. BTW: My console is produced with a base 1" flange for direct screw down install, which I won't do b/c I don't like holes in the deck, regardless of how much 4200, 5200 or Sikaflex or stainless screws, time and moisture will win eventually. I will also use square tube to install a future T-Top, but instaed of L angle, I'll use square tube sections glassed to the deck and then thru-bolt the bases to the tube. So, according to 'Hoyle', it sounds simple on paper- we'll see. |
hullinthewater |
posted 07-12-2013 12:48 PM ET (US)
sdfish- browsing the links provided by Qtrmeg, this seemed to be the best answer, straight form a similar years Montauk owner: Legobusier posted 08-31-2004 09:06 PM ET (US) |
sdfish |
posted 07-13-2013 12:34 AM ET (US)
Hull - yep, Ill use that as a starting point. I'd love to see your setup ideas, sound interesting. You may want to take a look at this link for ideas. http://www.bdoutdoors.com/forums/check-out-my-boat/164108-1962-boston-whaler-refit-picture-heavy.html I will install using aluminum angles screwed to he floor. |
hullinthewater |
posted 07-13-2013 02:47 PM ET (US)
I'll keep this thread updated. BTW: the more I thought about it, and the more I filled and Awlgrip'd the cockpit, the further I wanted to get away from thru-deck-screws. But that's just me: old boat-old dude....and the dude abides. sdfish- is that sd for san diego? |
sdfish |
posted 07-13-2013 11:21 PM ET (US)
Yep, I live in Carlsbad. Where are you located? |
hullinthewater |
posted 07-14-2013 12:19 PM ET (US)
What are the odds? I live near Batiquitos. Getting ready to install my rub rail today- I anticipate a minor struggle. |
sdfish |
posted 07-14-2013 10:16 PM ET (US)
Awesome. Let's see if we can get together an exchange notes. Hope all went well with the rub rail. I was able to get out and fish this morning. I fished the kelp in front of the power plant for a few small calicos. Beautiful morning on the water. |
hullinthewater |
posted 07-15-2013 02:46 AM ET (US)
Glad someone got the best of the day. I had to finish prep for a last Awlgrip to sumps and a couple exterior hull side repairs by previous owner. I wont have my console for at least 2-3 weeks, so I decided to wait on rub rail install later. Need to finish Awlgrip while engine is off. Next up will be electric harness and battery plans. Then control cables. Lots to do. Also need to factor out whether or not I want hydraulic steering. Add to that a fuel line hawser to tunnel. That will make a crowded tunnel. Still- good problems to have in life. yeah- drop me an email sometime to compare notes. |
