posted 07-08-2015 03:24 PM ET (US)
In that I was a little miffed, I can't remember whether [the aural alert horn sounding from a Mercury OptiMax outboard engine] was three BEEPS or four BEEPS. It was intermittent. I didn't check the time interval, but (from searches) it looks like [the cadence of the aural alert horn and its interval of sounding] could be a four-beep-every-two-minutes alarm--[which is to be interpreted as] non critical, get service alarm.Here is what I know:
--I had to jump start the Mercury OptiMax outboard engine
--the four-beep alarm went off when dockside at idle
--the oil tank under cowling is full
--the oil tank in hull is 1/2-FULL to 2/3-FULL
[the Mercury OptiMax outboard engine] is making water.
I took a couple of short [stints] in gear, but I didn't go full throttle. [The boat] jumped onto plane and seemed as though there were no limitations. It may be a coincidence, but the alarm did not sound while on plane, it only sounded when dockside, at slow displacement [boat speed], and (once) in a slow sharp turn.
In preparation, I ran the motor on ear muffs with no alarms. After running, I adjusted the throttle linkage limiting screw. It was not achieving WOT, i.e. the butterfly was not opening all the way. Possibly a red herring.
I reconnected the sensor to the fuel-water separator filter. It was not attached, I don't think I knocked it off, I think it was already disconnected.
I added OptiMax oil to the oil tank in the boat.
I have a wishful thinking theory--for a cheap easy fix--which [postulates that the cause of the alarm] would be the fuel-water separator. It didn't trigger on ear muffs for one of two reasons: the boat is stable and not bouncing around, and the sensor may have been disconnected.
[The cause of the alarm] may have something to do with low battery charge or voltage. It may have something to do with the oil sensor or, perhaps the cap on tank is not secure.
Many thanks to the folks on this forum and for Jim's strong work.
jws
