| Author | Topic: Transducer location on 17' Montuak |
| JT Dimmick |
I recently installed a Raytheon 470 fishfinder on my Montauk. The transducer is located about 18" from centerline as the manufacture suggested. I lose bottom and speed at about 12 to 15 mph. The old unit, an Eagle fishfinder held bottom into the high 20 mph. It was mounted closer to centerline, (too close according to the installer). Any suggestion to improve performance would be greatly appreciated. |
| dgp |
JT, I installed an Apelco / Raytheon transom mount x-ducer on my Whaler 2 years ago following the mfrs directions exactly and it performed normally all the way up to 40 mph. Check the protrusion depth below the hull and make sure it's set to the proper angle. Also make sure it's away from any hull strakes. Don |
| triblet |
18" from center line will be out of the water as soon as you are planing. On my Montauk, I originally mounted the transducer on the port side, 8" from center line. After some idiot (guess who) kicked it while trying to get up whaler's dumb one step ladder, I moved it to the starboard side. When I recently replaced the Humminbird Wide Optic with a Humminbird 3D Paramount, and having replaced the one step ladder with a three step, I moved it back to the port side. The 8" number was taken from a buddy's First off, you need to move the transducer, Chuck Tribolet |
| Walt Steffens |
JTD: In this I have some experience. I have owned 3 hulls of three sizes. I didn't follow the factory advice on any of them. I mounted the transducer dead nuts in the center of the transom, in the case of my 17 just ahead of the engine and on the 21 & 25 between the engines. I have encountered no problems and have been able to track or hold signal at speeds up thru 50 mph +. The units I used were all Hummingbird ranging from a flasher unit on the 17 to wide displays and 3d's on the 25. I mounted the transducer so as its leading edge was flush with the bottom of the boat at its deepest point using a straight edge as a gage. I have found that the water here is as clean or cleaner than any where on the hull. The only thing I had to be really careful of was that on the 17' single engine installation was that the tilt & trim was set so as not to let the leading edge of the lower unit strike the aft end of the transducer when the engine was tucked in all the way. I can't think of any reason that other manufacturers transom mount transducers wouldln't work equally well in this position. Hope this helps you out! WLS |
You might be interested to see how I mounted the transducer on my Whaler 15 Sport. The hull shape is pretty similar to the Whaler 17. There is a closeup of the transducer mounting in the article at: http://continuouswave.com/maintenance-logs/transomTransducer/ --jimh |
| JT Dimmick |
Thank you to everyone who replied!!! I moved the transducer to about 8 inches from centerline, everything is working perfectly. It holds bottom to over 40 mph and is very stable. Thanks. . . John |
