lhg
posted 06-09-2000 01:43 AM ET (US)
Dan: I highly recommend the 22 Outrage with a Whaler drive, since it will give you the full transom on the boat, and an improved ride. It will not, however, give you improved speed, because it's somewhat unusual design (for an engine bracket) has a bottom surface that runs in the water, increasing drag. But it's a great, beautiful boat and I'd go for it on that basis, assuming it's in good condition. I can't say, however, that I like the single engine on this model, since Whaler Drive was specifically designed for twin 25" shaft, counter rotating, engines. The single engine was a Dealer cheap-out solution to keep the price down, since Whaler drive added about $3000 to the price of the boat. And even worse, at 275HP I am assuming the engine is one of those OMC V-8s, a real gas guzzling, trouble prone, dog, long since abandoned by OMC as an outboard solution that didn't work. Any new 225 will run rings around it! (Mercury also made a short lived, big block V-6 275HP which was only a slightly better engine) So if you buy the boat, consider that you'll probably be repowering with twin 135's or 150's, at a cost of about $17,000 sometime soon. Then, you'll have a super MACHINE! |
