lhg
posted 07-05-2000 02:27 PM ET (US)
Dick: You need to drop the bunks down. First launch your boat and then drop the bunks down so they won't even touch the boat. Then retreive the boat, winching it all the way up on the keel rollers. (incidentally, to adjust the keel rollers, sight the length of the straight section of your hull, then stretch a string over those rollers to make sure they all line up - the rollers where the hull starts to curve up to the bow are harder to adjust properly and involve some guess work!) It will rock or lean over a little, but don't worry about it. You may have to re-adjust your winch stand and bow stop at this time also. (See Jim's picture on this subject). Then, snug your bunks up to the underside of the hull, as far out as possible, leveling the boat on the trailer, and tighten them to resistance, but not locking the bunks in place. Then, using a hammer, pound the supports on one side up REALLY snug against the hull and fully tighten the bolts. Then, put someone in the boat standing over the bunk you just tightened, and crank down the transom strap on that side also, and do the same on the other side. This will give you a really tight, rock-free installation, but all the weight will still be on the keel rollers. After a while, as the boat settles on to the bunks and compresses the carpeting, you will have to re-adjust the bunks again, using same method. This method works very well with any size Whaler, and you will be assured all the weight is on the keel. |
