lhg
posted 07-23-2000 12:12 PM ET (US)
Tom: Many people don't realize that stainless steel means "stain" "less" (than regular steel. It can exhibit surface rust, but this can usually be polished off the surface.Regarding counter rotation, the lower unit gear case is where it happens, but different shift controls are also needed. Mercury, for example, makes two twin engine control boxes - one for twin regular rotation, and one for twin counter rotation. I have a Whaler with both setups, and the counter rotation is far superior, eliminating the steering and port lean characterists of conventional rotation, which is magnified with twins. I've never heard of it being available below about 115hp, however. On my twin engine 18, which is non-counter rotating, getting rid of the standard twin cable mechanical steering in favor of hydraulic, helped a lot with the steering torque problems. |
