maverick
posted 02-14-2001 04:51 PM ET (US)
Hi, Jim - Compression checking and (lower unit check -I assume you pulled the oil plug from the skeg bottom toinspect the oil?). Those are good things, for sure. Quick checks, I'd also look for salt corrosion residue on the engine and lower unit. IF freshwater use only engine, that is better than salt use. I'd guess low hour use for a 5 year old motor is probably 150-200 hours, and if well maintained with those hours I'd guess will go twice that with normal use, with few if any problems. Are the hours documented by say an hour gauge? or just a guess? Are you buying this engine or have time to seriously inspect? If time is on your side, you may consider pulling the lower unit off and looking at the water pump, too. Easy job that will tell a lot about use.The 90HP block is a good one, and I'll bet that 115 is the same block with bigger carbs. Hope that helps, Best - Mav |
