posted 05-08-2001 11:50 PM ET (US)
You really need a working tachometer to evaluate the propeller situation.My 15-Sport (1976) has a 50-HP Merc (also 1976). The engine comes from the era of rating horsepower at the powerhead, not at the prop, so perhaps by today's standards it would be a 45-HP. It is also 25 years old, so maybe it is more like a 40-HP!
It had a 16-inch pitch 3-blade aluminum prop on it. When I got the tachometer installed I found the engine was only running to barely 5200 RPM. I was aiming for more like 5500.
I bought a 15-inch Merc BLACK MAX prop, another 3-blade aluminum but with cupped blades. (Diameter 10.125 inch). This got the revs up a bit, but I still felt the prop was too tall, especially with two adults aboard and all the gear, and in rough water.
I bought a 14-inch Merc BLACK MAX, and this has been the best prop so far. I can rev to 5500 rpm when lightly loaded, and the boat seems too handle better in rough water with the smaller pitch prop.
Of course, the pitch that is right is also a function of the gear ratio of the lower unit. I think the Merc is 2:1. Check what the Yamaha is before taking comparisons from these results.
