  Motor dies when tilted for shallow drive
Author Topic:   Motor dies when tilted for shallow drive
grandmufti posted 12-05-2001 09:51 PM ET (US)   Profile for grandmufti   Send Email to grandmufti
1979 115hp Evinrude.When I tilt the motor for shallow drive the motor either stalls or runs like it wants to stall.Any ideas?This just started recently
JBCornwell posted 12-05-2001 10:20 PM ET (US)     Profile for JBCornwell  Send Email to JBCornwell
I suspect that the diaphram in your fuel pump is getting a little weak, Grandmufti.
When you tilt her the carb floats put slight pressure on the needles even with almost empty bowls. Your pump may not be able to overcome that anymore. Another possibility is floats set too low.
A pump kit doesn't cost much, but if you want to verify it your manual should tell you what fuel pressure the pump should generate a cranking speed (ignition OFF, switch bypassed to the solenoid).
Good luck.
Red sky at night. . .
JB :)
grandmufti posted 12-05-2001 10:48 PM ET (US)     Profile for grandmufti  Send Email to grandmufti
Could I presume the float level is ok as it worked fine before.I am presuming the float level would not change unless manually adjusted.Could it have changed on its own?
triblet posted 12-06-2001 12:52 AM ET (US)     Profile for triblet  Send Email to triblet
Floats can take on gas. The metal ones
can leak, the plastic ones can absorb gas.
And the little tang that lifts the needle
can bend or wear.
grandmufti posted 12-09-2001 09:20 PM ET (US)     Profile for grandmufti  Send Email to grandmufti
New pumpkit on order.May have to wait for warmer weather to try it after it is installed.Thanks for the help,will keep you posted although it may be awhile before I can try it.
Whalerdan posted 12-10-2001 10:27 AM ET (US)     Profile for Whalerdan  Send Email to Whalerdan
How much did you have to pay for that pump kit?
grandmufti posted 12-10-2001 10:07 PM ET (US)     Profile for grandmufti  Send Email to grandmufti
I contacted Steve Leone in the for sale section of this forum.He had what I needed for 7.99 plus tax & shipping.He posted under PARTS PARTS.Shoot him an email.
