Topic: Hydrofoils
Salty |
posted 03-18-2002 09:41 AM ET (US)
I have a 17 SS Limited with a C-85 Yamaha. Getting a little porpoising, doesn't plane as quick, doesn't plane very well at slow speed. Thinking about a hydrofoil. Past experience with them was good. Looking at a Sting Ray but I see Doel Fin, SE Sport, The Edge, Atwood's gull wing job and others out there. Anyone with any experience with any of these on a 17'? Would love to hear from you. Thanks.
JBCornwell
posted 03-18-2002 11:38 AM ET (US)
Ahoy, Salty.I have a SE Sport 300 on one Montauk and a Doel Fin on the other. Both boats get up quicker and go faster than without them. Red sky at night. . . JB :) |
padrefigure
posted 03-18-2002 03:57 PM ET (US)
JB--do you run one of these on your OR18 as well? |
JBCornwell
posted 03-18-2002 04:05 PM ET (US)
Not yet, Padre, but I will put a SE300 Sport on it.Red sky at night. . . JB :) |
Bigshot
posted 03-18-2002 04:32 PM ET (US)
I do not run one on any of my whalers. You should not be porpoising if trimmed right and with that 85 you should be able to plane around 3k. My Montauk would hop on plane with the 90 and I weigh considerably more. Is she running right? |
Salty
posted 03-18-2002 10:22 PM ET (US)
I just had the motor put on by an authorized Yamaha dealer. It's running just fine. Plenty of power, good hole shot, 17 prop, motor is mounted all the way down on the transom in the last hole. Anti-cavitation plate is about 1/2" below the bottom. Had it trimmed under all the way and she still had a bit of porpoising and still needed to plane out a little more at slower speeds. My 18 gallon tank is a little more aft than it should be, something that I will remedy soon, and it was full. You could feel that it needed to be a little more balanced towards the bow. I wonder if a hydrofoil would put it there? If so, which one? |
Clark Roberts
posted 03-19-2002 05:44 AM ET (US)
Salty, I vote for the Doel-Fin! Also suggest that you raise engine so that anticavitation plate is 1"-1 1/2" above hull bottom! This will reduce underwater drag and should increase performance and handling but watch those revs and cooling water stream! happy Whalin'... Clark ... Spruce Creek Navy |
Ventura16
posted 03-19-2002 09:47 AM ET (US)
I vote for Doel-Fins...they made a huge difference for me...faster planing, ability to stay on plane at a lower speed, and a more usable trim range.Tom |
Salty
posted 03-19-2002 12:21 PM ET (US)
Has anyone had any experience with the "Sting Ray" hydrofoil? They are fairly large with a downturned trailing edge. |
Arch Autenreith
posted 03-19-2002 12:33 PM ET (US)
I have one of those 'huge' ones but can't remember what one it is. I know there's a thread somewhere around here but can't find it easily at them moment.Anyhow, I didn't like it and took it off so my offer still stands. I think I paid $25 or so dollars for it and I'll send it free if anyone wants it. |
Arch Autenreith
posted 03-19-2002 01:30 PM ET (US)
John from CT is now the proud new owner of it. |
OutrageMan
posted 03-19-2002 01:43 PM ET (US)
I had a Stingray on my 22 OR w/ WD and 250 Yamaha. It was the saving grace of the boat and the best money I have ever spent on it.I bought the fin to try to help compensate for the torque list caused by that big engine. It almost completely eliminated it. Additionally, time to plane was significantly shortened. A little story about that time to plane. After installing the Stingray, my father and I decided to water test it. Obviously in the slow no wake zone of the channel, there was no effect. When we cleared the channel, I ained the boat out to sea, and from a dead stop hammered the throttle to see how fast I could get it to plane. When she immediately came out of the pocket, I learned a very important lesson about using that fin. You see, the added lift on the transom forced the bow down very quickly and sharply. When the bow cane in contact with an oncomming wave, we hit very hard. It was the only time I have ever thought I was going to pitch pull a boat. If it wasn't for the T-top standards to hold on to I think Dad and I would have been thrown to the bow. Needless to say that after that I was quick with the trim as soon as the boat began to break from the pocket. Brian |
Bigshot
posted 03-19-2002 01:44 PM ET (US)
Raise that engine before you buy anything. too low is a problem. |
John from Madison CT
posted 03-19-2002 02:13 PM ET (US)
Arch, Thanks, I appreciate it. I will post the results here once I get a sense of how it does on my Montauk with 90hp Yammie. If things don't work out, I will offer it for free to the next guy who wishes to try it. Muchas Gracias ! John |
Salty
posted 03-20-2002 10:49 AM ET (US)
Many thanks to all for your comments
ratherwhalering
posted 03-22-2002 03:14 PM ET (US)
I am considering installing a dole fin, and I was wondering if I will need to raise the engine once the fin(s) are bolted on. The fins are thick, and look like they will add 1/4 inch thickness to the cavitation plate, although in the aft section of the plate. Any experiences with this? |
OutrageMan
posted 03-22-2002 03:24 PM ET (US)
No need to raise your engine.Brian |
lhg
posted 03-22-2002 05:34 PM ET (US)
All of those engine mounted "stern lifters" are speed killers (because of additional drag) if they don't pop clear of the water flow once plane is achieved. So you have to hang your engine up a hole or two to achieve this. Otherwise you'll lose about 3mph top end. So depending on where your engine is now, you may, or may not, have to raise it.Clark Roberts is our "resident expert" on this subject, and I believe this is his finding. |
acseatsri
posted 03-22-2002 10:17 PM ET (US)
If the hydrofoil is out of the water at planing speed, doesn't this defeat the purpose for which it is intended? I'm putting one on this year just so that I can run on plane at a slower speed when offshore. It's almost impossible to run anywhere near WOT on LI Sound. 18OR planes at around 16 knots now, was hoping for 12-13 with the fin. Also moving the batteries inside the console to redistribute weight, compensate for 85 pound kicker being added. |
boxers
posted 03-28-2002 09:59 PM ET (US)
THe doel-fin on my 13ft 40th anniversary transformed the boat. The performance difference was AMAZING. I put a big Honda 40HP on the back and counldn't get the trim right. With the fin on the boat is a breeze to trim and the motor is whisper quiet. TWO THUMBS UP |
posted 03-29-2002 05:45 PM ET (US)
Arch, You're a gentleman and a scholar !! Got the Hydrafoil in the mail today. Danke Schoen, Muchas Gracias, Efharysto, Gratzie, ..... Thank you ! John from Madison, CT |
Arch Autenreith
posted 03-29-2002 09:32 PM ET (US)
You're welcome. But we need before and after specs!!!Arch. This may become a Continuouswave hydrofoil if it doesn't work out for you. Keep passing it to the next person 'til it finds a rig it likes. Lol. |
kamml
posted 03-31-2002 09:40 AM ET (US)
I had put a Doel on my previous Merc 50/Montauk. It made a noticeable difference on time to plane and lower speeds on plane. I read somewhere after I had mounted it by drilling two holes in the cav. plate that a single hole would work just as well and lessen the chance of any damage to the cav. plate caused by an under water strike to the fin. My repower 90 Merc. pops on plane without the fin, so no need for one at this point for this motor. I would advise trying it with only one hole in the cav. plate first. Ken |
