Topic: Will a jack plate work?
JFM |
posted 04-12-2002 10:35 AM ET (US)
I have discovered that I can use an adjustable jack plate from CMC to solve my problem with my 15' transom. However should I be concerned with too much weight? The 2000 Yamaha weighs 181 and the jack plate weighs 20 lbs.. Also the motor will set back 4"s. Thanks, Jay
JBCornwell
posted 04-12-2002 10:40 AM ET (US)
Hi, Jay.Two hundred pounds is not too much on a 13, but I would use a lighter, fixed jackplate. Several of us have used JPs to mount new engines on Montauks and the results have been very good, while avoiding blind holes or lag screws. Red sky at night. . . JB :) |
JFM
posted 04-12-2002 11:01 AM ET (US)
Thanks JB, I need the adjustable to lower the motor. However, if I use a fixed, will the motor be lower because of the 4' set back? Thanks, Jay
Bigshot
posted 04-12-2002 12:24 PM ET (US)
Jay your becoming a pain :)20 lbs won't do anything...go for it. You can always remove it and sell it here if not happy. You can also make something custom. |
JFM
posted 04-12-2002 01:56 PM ET (US)
Nick is there a masochism side to you too:). With all the issues of Chainsaw Whaler, water in the hull, too much weight on the transom, I'm trying to cut through the crap and get some good answers before I ruin a damn good boat. Regards, Jay |
Bigshot
posted 04-12-2002 02:14 PM ET (US)
I've given you all the info. you need Jay:) |
