  50 hp evinrude
Author Topic:   50 hp evinrude
jlangan posted 04-29-2002 05:43 PM ET (US)   Profile for jlangan   Send Email to jlangan
My 50 hp evinrude w/ VRO was run dry by a well intentioned soul last fall. Now after rebuilding the carbs (full of oil) the engine will not idle. Runs strong at top end but can not get a smooth idle at all. Any help?
JBCornwell posted 04-29-2002 06:29 PM ET (US)     Profile for JBCornwell  Send Email to JBCornwell
Hi, JLangan.
The idle orifice is the smallest opening into the carb throat (just downstream from the throttle plate). I suspect your overhaul failed to fully clear one or both.
Good luck.
Red sky at night. . .
JB :)
Bigshot posted 04-30-2002 10:22 AM ET (US)     Profile for Bigshot  Send Email to Bigshot
Make sure the choke(enrichner) is not on. It is that small red tab near the air valve next to your carb or fuel pump. If you leave that on it will act like the choke is on. Make sure uit is turned so it "clicks" into an indent.
jlangan posted 05-02-2002 09:14 AM ET (US)     Profile for jlangan  Send Email to jlangan
Thanks I'll check this out.
