  Prop recomendations for Montuak
Author Topic:   Prop recomendations for Montuak
jameso posted 08-03-2002 10:01 AM ET (US)   Profile for jameso   Send Email to jameso
I have a Law Enforcement Special, which is a commerical (heavier more glass and resin, 150 lbs) Montauk with 115 OMC, what are you guys with 115's on Montauks slinging? I have a 21 now and dealer will trade, get 4400 RPM's at WOT, cannot trim any higher.
Thanks Jim Armstrong
pamlico posted 08-03-2002 09:20 PM ET (US)     Profile for pamlico  Send Email to pamlico
What is your RPM operating range?
For example my V-6 is rated 5000-5600 RPM's.
jameso posted 08-04-2002 09:14 AM ET (US)     Profile for jameso  Send Email to jameso
Don't want to take the RPM's over 5500.
whalersman posted 08-04-2002 05:09 PM ET (US)     Profile for whalersman  Send Email to whalersman
jameso,
It sounds like you have too much prop. I assume you are saying you have a 21 pitch prop. What diameter of prop is it?
A friend of mine has a Johnson 115 and his prop is a 14" Diameter by 17 pitch. His engine runs about 5250 RPM at WOT.
Try using a prop with less pitch. Your RPM's should go up. When you get the right pitch and diameter of prop, your wide open throttle should be between, (about) 5000 and 5500 RPM.
Joe
whalersman posted 08-04-2002 05:19 PM ET (US)     Profile for whalersman  Send Email to whalersman
jameso,
Joe
