  What Tachometer?
Author Topic:   What Tachometer?
Jiles posted 08-30-2002 09:32 PM ET (US)   Profile for Jiles
I need a tachometer for my 1986 Johnson 40. Where is the best place to buy a tachometer for this application and what do I need to buy to hook it up? I have a Johnson motor control with a three prong connector labled TACH.---THANKS---
whalersman posted 08-31-2002 02:35 PM ET (US)     Profile for whalersman  Send Email to whalersman
eBay is a great place to look for a Tach. I would purchase an OMC Tach for your engine (not the Tach with the new System Check).
You may also need to buy a Tach Harness to plug into your existing 3 prong connector depending on which model Tach you purchase.
You should also be able to pick up a new Tach at your local OMC Dealer. About $120.00 (yikes)
Dr T posted 08-31-2002 04:18 PM ET (US)     Profile for Dr T  Send Email to Dr T
If you need any help finding the right one, I would suggest going to the Cabela's website at www.cabela.com. I picked up a Tach there for my 1982 Johnson 35. Check to see if your remote has a place for a wiring harness to plug in. If so, get the adapter and the hookup is a no-brainer.
tds
