  Recalls (2) on Honda 115 & 130 hp.
Author Topic:   Recalls (2) on Honda 115 & 130 hp.
AC posted 09-03-2002 05:40 PM ET (US)   Profile for AC   Send Email to AC
FYI:
I just received letters from Honda Marine announcing two different recalls on Honda BF115 and BF130 outboards. They are:
1) Problem - the high-pressure fuel pumps may develop corrosion, resulting in failure.
Resolution - an improved replacement high-pressure fuel pump/water separator will be installed at no charge.
2) Problem - "a small number of these motors have developed localized cylinder head and/or engine block casting cracks. These cracks may cause internal water leaks and reduce the performance characteristics."
Resolution - American Honda is extending the warranty on the cylinder head and/or engine block assembly to a period of 10 years from the date of original retail purchase.
If you have previously paid for this repair, contact: American Honda Motor Co., Inc.
Customer Service Dept.
4900 Marconi Drive
Alpharetta, GA 30005
(770) 497 - 6400
AC posted 09-03-2002 05:50 PM ET (US)     Profile for AC  Send Email to AC
Forgot to mention that Honda will authorize a one-time complimentary inspection of the cylinder head and engine block castings.
Salmon Tub posted 09-03-2002 09:24 PM ET (US)     Profile for Salmon Tub  Send Email to Salmon Tub
Have them check it at the end of the warrantee period.
Bigshot posted 09-04-2002 10:09 AM ET (US)     Profile for Bigshot  Send Email to Bigshot
make sure it is not prorated first. I guess a cracked block could impede the performance characteristics.....what a bunch of BS.
creeble posted 09-04-2002 12:13 PM ET (US)     Profile for creeble  Send Email to creeble
FWIW: I was in Tonga in May and the mechanics there were Honda-haters because of the 100% failure rate of fuel pumps. They corrode when not used for a week, and are a total b**ch to replace. Maybe the new ones are better.
Eric.
