  Mounting a 175 Merc on a 19 outrage...HELP!
Author Topic:   Mounting a 175 Merc on a 19 outrage...HELP!
Lkart67 posted 09-09-2002 07:43 PM ET (US)   Profile for Lkart67   Send Email to Lkart67
I'm putting a 175 Merc on my '73 19'outrage & the bottom mounting holes are so low if I drill new holes they would come out below the cover in my livewell and be unaccessable. My question is, can I cut an access hole from inside my live well to access the washers & nuts, and then install a waterproof deck plate? or is that area between the livewell & transom filled with foam? Any other suggestions would be greatly appreciated.
bsmotril posted 09-10-2002 09:46 AM ET (US)     Profile for bsmotril  Send Email to bsmotril
Why not drill a small diameter test hole through the live well land find out for sure. You can easily patch it with caulk if you decide against the access port. Even if there is foam back there, no reason why you could not dig it out to install the engine mounting bolts.
BillS
Bigshot posted 09-10-2002 02:20 PM ET (US)     Profile for Bigshot  Send Email to Bigshot
Where are the old bolts? I do not remember having any problems on my 74 Revenge with modern power.
Capt_Tidy posted 09-10-2002 07:27 PM ET (US)     Profile for Capt_Tidy  Send Email to Capt_Tidy
Why not add a setback/ engine bracket to help?
Lkart67 posted 09-11-2002 10:32 AM ET (US)     Profile for Lkart67  Send Email to Lkart67
Lower bolt holes on merc are about 3 to 4" lower than the Johnson which put them lower than the top of the livewell
Al
