posted 11-14-2002 11:31 AM ET (US)
Thanks to all of you for your willingness to help Whaler neophytes like myself. I have been reading the forum for about 6 months and have greatly ejoyed and benefited from your discussions.After seeing my Brother-in-Law's Classic Whaler(he is known to many of you as Chesapeake), this past summer I purchased my own 1966 13' Sport for $1,000. It came with a 1972 Evinrude 50 hp that has electric push button shift. The boat needs a little TLC(i.e., a few nicks in the gelcoat,polish, new rub rail, and refinish the wood), but is generally in very good condition.
As with most things that seem to good to be true, a problem has arisen. We had a blast the few times we took the boat out this summer, but then had an outboard problem. Thanks to all of you for your willingness to help Whaler neophytes like myself. I have been reading the forum for about 6 months and have greatly enjoyed and benefited from your discussions.
After seeing my Brother-in-Law's Classic Whaler (he is known to many of you as Chesapeake), I purchased my own 1966 13' Sport this past summer. It has great rails around it and came with a 1972 Evinrude 50 hp that has the old electric push button shift. The boat needs a little TLC this winter (i.e., a few nicks in the gelcoat, polish, new rub rail, and refinish the wood), but is generally in good condition.
Most of our boating is on the Upper Mississippi river as it passes through Southwest Wisconsin/Northeast Iowa. We have a 1986 19 ft Larson boat that is very comfortable for cruising the main channel, water skiing, etc. that we keep in Wisconsin. The purpose of the Sport is mainly for fishing and bird watching in the shallow backwaters, lakes, and sloughs of the Mississippi. In many of these areas, the water is only a couple of feet deep and you need to negotiate through sandbars and fallen trees. However, we also tow the Sport about 100 miles back to our home in Iowa City where we like to take the kids tubing and fishing on a reservoir near our home.
The Sport was wonderful the few times we had it on the water this summer, but our last time out the Evinrude would not start. My mechanic identified the problem as a faulty ignition part for which he could not find a new replacement. The repair would cost a couple hundred dollars if he could locate a used part, but he strongly recommended my buying a new or late model outboard because he considered my old electric shift model an unreliable sinkhole for cash. The unreliable part is a big concern since I plan to take the boat into pretty remote locations with my family. The mechanic is trustworthy and is not trying to sell me a new engine, so I am inclined to replacing the Evinrude. Although I have no intention of selling the boat, the resell value of a clean 13’ Sport with a late model engine would seem to support the investment – at least that is the justification I plan to use with my wife!
Although I enjoyed the “rocket” type performance with the high hp Evinrude, we place a higher priority on having a reasonably quite engine that performs well in shallow. Nonetheless, obtaining a plane with a couple adults in the boat and tube behind us is important when we are back home and don’t have access to our larger boat. In past threads on powering a 13’ Sport, most members adopted the reasonable perspective of trying to optimize a single applications (i.e., power or fishing) rather than a compromise. My interest is in finding an economical compromise that will work across our applications even if it is not optimal for one application.
So, here is where I need your good advice. First, the mechanic who recommended changing the motor is an honest guy, but do you agree with his opinion about my current Evinrude? My preference is to put off upgrading the outboard for a couple years, but getting stranded next summer in a remote setting on the river would definitely make this an unacceptable option. Second, a different dealer has a 1998 Evinrude, 25 hp, 2-stroke, short-shaft that he will install on the boat with new remote controls for $1,700. The motor has low hours on it and the shallow water drive option, which should be helpful in the backwaters. This sounds like a good solution for our shallow water needs, but will it be enough power to achieve a plane with four adults or pull some kids around the lake on skis or in tubes? Is $1,700 a fair price?
Thanks for your advice.
John
