  20' Guardian w/200 OMC - engine mounting
Author Topic:   20' Guardian w/200 OMC - engine mounting
Fishcop posted 11-17-2002 10:25 PM ET (US)   Profile for Fishcop   Send Email to Fishcop
1989 Guardian w/1989 200 OMC VRO (Just aquired from the Feds). Sprays a rooster-tail and looks like the motor is too low. Before we send it to the "experts", any idea what mounting hole the engine should be mounted on? Would like to fix it without the paper work hassel.
Thanks,
Andy.
Bigshot posted 11-18-2002 10:30 AM ET (US)     Profile for Bigshot  Send Email to Bigshot
Go all the way up and see how it does. Tad easier to lower than raise. One thing though is that must be one well built engine to last 14 years on a gov boat. I thought the had to repower every few years but I guess not.
lhg posted 11-18-2002 06:07 PM ET (US)     Profile for lhg
The Vee shaped spray coming off an engine is a definite indicator of engine mounted too low. BW recommend for that hull that engine be raised one bolt hole (3/4"). But with that much power, you might want to consider 1-1/2". Consider an OMC "Raker" prop, or similar Mercury Laser II. For the best holding in rough water, at this transom height, try the 4-bladed Offshore that Louie Kokinis uses on his Guardian.
Fishcop posted 11-19-2002 01:14 PM ET (US)     Profile for Fishcop  Send Email to Fishcop
Thanks guys. I will make the changes and let you know how it goes.
Andy.
