  Prop advice
Author Topic:   Prop advice
63WHALER posted 11-28-2002 03:58 PM ET (US)   Profile for 63WHALER
I have a 1984 OMC v-4 engine on a 17' pre-smirk hull. Currently has the stock alum. prop which is 13 1/4 x 17. Not sure of RPM at WOT, but am satisfied with holeshot and top end speed, also not sure of speed at this time. Was thinking on upgrading to a stainless prop although. Found a deal i think on a Solas 13 x 21 new stainless prop for $100. My question is how will this prop perform to what I,m currently using? Forgot to add this is a 90hp engine. Not very familiar with propping, so any advise and input greatly appreciated.
Thanks,
63
OutrageMan posted 11-29-2002 01:08 PM ET (US)     Profile for OutrageMan  Send Email to OutrageMan
Frankly, any advice given here would not be very accurate without at leas knowing what RPM's you are running now.
Brian
Dick posted 11-29-2002 01:54 PM ET (US)     Profile for Dick  Send Email to Dick
I agree with OutrageMan on this one.
There are a couple rules of propping that will kick in without knowing the top RPM and speed though.
1. As you increase pitch you will loose top RPM.
2. As you increase pitch you will probably loose hole shot.
3. As you increase pitch you may pick up top speed.
Don't buy that prop untill you have at least a wide open RPM with the prop you are now running.
Bigshot posted 12-02-2002 09:17 AM ET (US)     Profile for Bigshot  Send Email to Bigshot
21" no way in hell. 17" for a 90hp, maybe a 19" on a 115.
TightPenny posted 12-02-2002 11:14 AM ET (US)     Profile for TightPenny  Send Email to TightPenny
I agree.
17" pitch SS Rapture for a 2001 90hp Johnson on my Montauk maxes out at around 5200 RPM
Don't go any steeper on the pitch.
Sal DiMercurio posted 12-03-2002 01:20 AM ET (US)     Profile for Sal DiMercurio  Send Email to Sal DiMercurio
Don't even think about it, it's not the prop for your outfit.
Believe me, if your engine has survived 19 years with a 17 pitch prop, the 21 is certainly not for you.
Think of it this way, your driving your stick shift pickup, pulling a 4,000 lb boat, you come to a steep hill, your foot is to the floor on the throttle, your now going 25 mph, but still in 5th gear, thats what will happen to your engine.
Going from a 17 to a 21" pitch prop is going to take 800 rpms right off the top of your engine, & that aint good.
I know your "NOT' running 800 rpms over your recommended max rpms now.
Sal
