ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Performance Tranducers for Montauk-Thru-hull or transom?
Author | Topic: Tranducers for Montauk-Thru-hull or transom? |
kentupps |
posted 02-08-2003 08:03 AM ET (US)
I,ve been really up in the air on wheather to go with a thru-hull or transom mounted transducer for a fishfinder. I would think it would be a sin to chop a hole in my Montauk. Does anyone have any experience with this in their own boat? Transom or thru hull experience? |
acassidy |
posted 02-08-2003 08:24 AM ET (US)
I mounted mine on the transom port side just like this article says. [url] http://continuouswave.com/maintenance-logs/transomTransducer/ [/url] It works at all speeds. |
weekendwarrior |
posted 02-08-2003 09:14 AM ET (US)
I used a transom mount and it works pretty good. I did not find this site before mounting it so I just mounted it sticking about 1/4" below the hull about 3" to the right side of the center. It works good most of the time, going fast in choppy water can cause it to see fish that aren't there otherwise it's pretty solid. |
posted 02-08-2003 11:08 AM ET (US)
My thoughts on this topic are presented in an article I published in the REFERENCE section. See: http://continuouswave.com/whaler/reference/sonarTransducer.html |
lhg |
posted 02-08-2003 02:34 PM ET (US)
Transom, transom, transom. Lowrance, Lowrance, Lowrance. Best little skimmer tranducer on the market. Jim's article shows this transducer. |
kingfish |
posted 02-08-2003 02:41 PM ET (US)
Larry- I can't tell for sure in the photo you reference, what the shape of that skimmer transducer is - I'm probably not focusing my eyes right, but it looks like we're seeing what amounts to the opening of a horn-shaped device, pointing rearward?? |
lhg |
posted 02-08-2003 03:55 PM ET (US)
Hi John Yes, the close-up photo shows Jim's perfect installation. As you can see, the rounded "skimmer" bottom is perfect for a Vee hull boat. It kind of planes through the water, with no spray at all, and very compact (about 2" long), and mine read even at 60 mph. I think it's patented, as nobody else has anything that even comes close on small size, easy installation and clean running at high speed. For a long time, I have thought that one of the most overlooked features when buying a sonar is the transducer design. Believe it or not, the main reason I buy Lowrance/Eagle is for this skimmer transducer! These transucers read to about 450'. For deep water (down to 2000'), lower frequency applications, Lowrance makes a much bigger skimmer, but it is a bear to install for clean running and no spray. I finally gave up on using one of those while running! |
kingfish |
posted 02-08-2003 04:17 PM ET (US)
What does it look like from the side? And/or from the top? |
kingfish |
posted 02-08-2003 05:43 PM ET (US)
Larry, never mind- It dawned on me (duh) I could go to the Lowrance website and look at one. They are different from the transducers I'm used to with flat bottoms. Anyway, curiosity satisfied. |
Guts |
posted 02-09-2003 09:24 AM ET (US)
is this a trick question? go on cut a hole in the boat! Guts |
Tom W Clark |
posted 02-09-2003 01:22 PM ET (US)
Without a doubt, use a transom mount transducer. I agree with Larry, the Lowrance Skimmer is a superior product. Mount it on either the port or starboard side, it won't make much, if any, difference. The Lowrance Skimmer does not have the "mini trim tab" effect that old fashioned transducers did. A transom mount transducer will allow changes in the future while a through hull transducer will be there forever even if you do buy another fishfinder at some point (and you or the next owner will). |
Sal DiMercurio |
posted 02-09-2003 11:36 PM ET (US)
Rule of thumb. Inboard, = through hull. Outboard, = Transom mount. Sal |
waterwal |
posted 02-09-2003 11:51 PM ET (US)
I was quiet on this one because I figured there was an advantage to the port side mount I was so far ignorant of...Tom's advice prompted my reply. My transducer is on the starboard side. I have no problems with it. I have a right handed prop too. There may be some negligible performance enhancement on the port side, but again, I have no problems with mine. |
doobee |
posted 02-10-2003 01:05 AM ET (US)
Transom mount is the only way to go. I've had great success with Lowrance. They make the best color sounder available. If you're fishing very shallow water (less than 70')Humminbird may have an advantage with their extra wide angle, multibeam transducers. Their transducer is flat bottom but some are pretty small. whale on |
Guts |
posted 02-15-2003 10:45 PM ET (US)
Author Topic: Tranducers for Montauk-Thru-hull or transom? kentupps posted 02-08-2003 08:03 AM ET (US) -------------------------------------------------------------------------------- I,ve been really up in the air on wheather to go with a thru-hull or transom mounted transducer for a fishfinder. I would think it would be a sin to chop a hole in my Montauk. Does anyone have any experience with this in their own boat? Transom or thru hull experience? Guts posted 02-09-2003 09:24 AM ET (US) -------------------------------------------------------------------------------- is this a trick question? go on cut a hole in the boat! Guts doobee posted 02-10-2003 01:05 AM ET (US) whale on captbone posted 11-25-2002 02:23 PM ET (US) Red sky at night. . . dfmcintyre posted 11-25-2002 07:10 PM ET (US) It's located to the left of center, up forward. To access it, the cover that covers the forward bilge area (it's the one that is about 3-4"? deep) needs to be opened up (probably pretty dirty in there). From what I recall, the area I'm talking about is towards the (looking aft now) in the rear right corner of the bilge. We mounted one there. Worked "ok". At speed it would have a tendency to lose effectiveness and made an odd noise, when the surface of the water was hitting at the right ange against the mounting block (oh, did I mention that you need to fabricate a mounting block for the correct angle? Make it out of epoxyed mahogany) Nice thing about it way up forward, was at dead idle, we'd spot things before it got challenging. Don Fishcop posted 11-26-2002 12:16 AM ET (US) -------------------------------------------------------------------------------- Eagleman, -------------------------------------------------------------------------------- Guys, theres a simple rule to follow. -------------------------------------------------------------------------------- Go on do it! I did! and I also have a transum mount,also. The thru hull WILL WORK BETTER! now with that said. the b.s. about cutting holes in the hull, it's not all that hard to do. In fact furuno (or airmar)sends the how to do cored hulls with there ducers. Guts an in hull transducer will not work unless you remove all the foam down to the outer layer of glass (easier said than done. you can not have any bubbles between the transducer and the water. if there are bubbles trapped in the outer layer of fiberglass laminate the in hull transducer will not work properly Guts posted 12-20-2002 08:49 AM ET (US) -------------------------------------------------------------------------------- doobe I desagree with you. now in a montauk and only a montauk, that I am talking about. what I have been trying to say, is that more than two people this year have asked about thru hull ducers. now I have done this and think I am able to say that I know what I'm talking about. but I can not spell worth a darn! as you can see. -------------------------------------------------------------------------------- guts,a transducer is just a ceramic element encased in lexan regardless of whether it is a transom mount, or thru hull. all other factors being equal, there should be no difference in performance while the boat is at rest. Transducers are designed to operate at specific frequencies and beam angles. if your transom transducer has a wider beam angle or a different frequency than your thru hull, that could account for the difference in performance. the difference in performance could also be due to some manufacturing defect, corrosion in the plug, a knick in the wire, scratched transducer, etc. if i remember correctly, your fish finder is a dual frequency model. are you using a dual freqency transducer in both cases? Does the transom mount performance change if you change frequency on the fish finder? there are no nicks in the wires or any thing wrong with the wireing,I do all the work on my boat myself. so I know that there is done right. doobee posted 12-29-2002 09:00 PM ET (US) otherwise i'd say your transom mount is either defective, or it's the wrong frequency. bigz posted 06-10-2001 03:51 PM ET (US) That said, here pull up this thread from the General Topic area -- lots of post and opinions enjoy -- jimh posted 06-10-2001 04:45 PM ET (US) jimh posted 06-19-2001 09:26 AM ET (US) A well set-up trailer that easily transports, launches, recovers, and stores you Whaler is essential to proper "performance." Trailers are adaptable for modification, improvement, re-fitting, and repair. Let's look at the question, "What is the best fishfinders [sic] on the market?" This is a very broad question. There are no criterea for judgement. Are we discussing best price, best performance? What depth of water? Salt or Fresh? Fishfinders don't enhance the performance of the boat, that is they don't make it run faster, use less fuel, become easier to operate, etc. People visit the forum because, in most cases, it provides a high ratio of on-topic content to off-topic clutter. The fundamental goal of the website has been to collect and distribute high information-content, on-topic material on the various subjects. As for bigz, he is a very valuable contributor and I think his comments are on target here. Kim posted 04-06-2001 06:16 PM ET (US)
posted 02-16-2003 08:08 PM ET (US)
Was the moon recently full? We appear to be under the assault of a one-man campagn to rewrite the conventional wisdom on where and how to mount a transducer. No matter how many old postings are revived, the overwhelming majority of people will use transom-mount transducers on their Boston Whalers. |
Guts |
posted 02-16-2003 10:19 PM ET (US)
Yes jimh they do use transum mount. as i went back thur(no pun intended)the old post.i found what i was looking for, that is that other people are asking about other than transum mount.but the over all you included (this your site i know) will not acept the fact that a thru hull works better than a transum mount. I would NEVER drill that big of a hole in any hull below the waterline! That is a big risk, plus the benefit is not really worth it. Agreed. Thru-hull and Whaler are incompatible. A correctly mounted transom transducer will do anything any thru-hull will do. a transducer is just a ceramic element encased in lexan regardless of whether it is a transom mount, or thru hull. all other factors being equal, there should be no difference in performance these are not true! now(a transducer is just a ceramic element encased in lexan regardless of whether it is a transom mount, or thru hull. all other factors being equal, there should be no difference in performance)they are not equal this what i an talking about. there are many factors to look at, such as the element. at the boat show i asked the furuno rep Lenard about this. after i told which tranducers i have, acamsBR7 and a 520-5pwd 50&200KHz dual. his reply was there is no way!you could get the same reading. the thru hull will be better. he also told that airmar has a tramsum mount that will work as good but it was a tube typ thing that mounted to the transum that is lowered when in use. and raised when on the way. he told me that Steve at airmar(ithink that was the name he used) is working on a new transum mount transducer that work as well as a thru hull. |
Matthew |
posted 02-17-2003 01:13 AM ET (US)
It may be time to switch to Decaf. ;) Matt |
frostbite |
posted 02-17-2003 09:12 AM ET (US)
I don't think that I would take much advise from someone who cannot even spell transom. As we used to say in school, "Last week I couldn't even spell engineer, now I are one." |
frostbite |
posted 02-17-2003 11:26 AM ET (US)
I wouldn't advise taking advice from someone who can't spell advice either. |
Guts |
posted 02-17-2003 07:43 PM ET (US)
frostbite ya it is to bad jimh dose not have a edit in this form. |
posted 02-24-2003 09:12 AM ET (US)
Heya Guts, Lack of an edit function should not hold you back. I don't want my limitations at running this forum to affect your technical writing. Therefore I will make you this offer: Please send me an article (with illustrations and photographs if possible) that describes your transducer installation technique and documents all the advantages it offers. Be sure to use your best editing skills. If you send me an article that contains no misspelled words and no gramatical errors, I will post it in the Reference Section. Send me an article filled with malapropisms, misspelled words, and undocumented results, and I will not publish it. This offer is good for one year. |
