  Telltale water stream on '94 Yamaha 85 in cold weather
Author Topic:   Telltale water stream on '94 Yamaha 85 in cold weather
Kelly posted 02-24-2003 01:00 PM ET (US)   Profile for Kelly   Send Email to Kelly
I have not been out in the boat for a while, so on Saturday I decided to hook up the muffs and crank up the motor. Battery was dead, so I just pull started the motor. It took more pulls than I had hoped, about 9, but once it fired it was fine.
The telltale water stream was not putting out water. It seemed like a very little bit was dripping out, but not a stream like I am used to seeing. It worked the last time I was out on the lake. I felt the motor, and it was not hot at all, even after several minutes of running. The water from the hose was pretty cold. I had the impeller replaced last spring.
Does the motor have to reach a certain temperature before water starts coming out of the telltale? If not, where would you start looking for the problem? New impleller? Clogged hose? Other?
Kelly
Bigshot posted 02-24-2003 01:11 PM ET (US)     Profile for Bigshot  Send Email to Bigshot
Run a wire up the tell tale hole or weedeater line. It is probably just clogged. Some engines also don't like running on muffs.
Kelly posted 03-09-2003 09:52 PM ET (US)     Profile for Kelly  Send Email to Kelly
Used the weedeater line yesterday and that did the trick. I have added that as an item to keep on the boat.
Thanks, Kelly
