  Montauk/115 4-Stroke=?? Prop
Author Topic:   Montauk/115 4-Stroke=?? Prop
dogfish2 posted 04-12-2003 02:48 AM ET (US)   Profile for dogfish2   Send Email to dogfish2
Just mounted a 115 4S MERC on a Montauk. Running a 19" Ballistic and getting 43 mph @ 5300 rpm's medium load. Should be running 5500-6000 rpm's according to "experts." Does anyone have a similar boat/motor set-up, and what propeller/pitch works best for you? I am also open to any suggestions or advice. Thank you.
tabasco posted 04-12-2003 09:49 PM ET (US)     Profile for tabasco  Send Email to tabasco
What year Montauk?
dogfish2 posted 04-12-2003 11:08 PM ET (US)     Profile for dogfish2  Send Email to dogfish2
The Montauk is model year 2000. The problem might be with the motor not opening up fully at the top end and not the prop selection. I ran a 90 4 stroke MERC on the boat before and got the almost the same top end speed. So, I suspect that something is amiss. Would appreciate any comments. Thanks.
tabasco posted 04-13-2003 10:53 PM ET (US)     Profile for tabasco  Send Email to tabasco
I'm running the Vengence prop that came on the 90 HP 4 stroke. It's now on a 115 HP 4 stroke on a new Montauk 170 with a top speed GPS of 50.3 MPH. Actually the prop had a little nick in it so I had it redone over the winter. I will see this year if it ups the top speed.
dogfish2 posted 04-13-2003 11:17 PM ET (US)     Profile for dogfish2  Send Email to dogfish2
What pitch is the Vengance that you are running on the 115 4-S? The speed sounds about right. Mine is still new, but it does not seem to have any power/speed at the top end. Hopefully, it will only be a minor adjustment. Thanks for you response.
Bigshot posted 04-14-2003 08:58 AM ET (US)     Profile for Bigshot  Send Email to Bigshot
I doubt you will get 50 on a montauk. My 76 had a 115 and it did maybe 46 on a good day and that was a 2 stroke.
tabasco posted 04-14-2003 08:59 PM ET (US)     Profile for tabasco  Send Email to tabasco
Hey bigshot are you doubting me? ;-) Unless Sadam has interrupted the satalites........ then my Garmin 2006c is acurate and it says top speed 50.3 MPH.
Bigshot posted 04-15-2003 01:24 PM ET (US)     Profile for Bigshot  Send Email to Bigshot
You have a different Montauk than the one i was referring to....sorry.
dogfish2 posted 04-15-2003 06:22 PM ET (US)     Profile for dogfish2  Send Email to dogfish2
Both of you are correct! I understand that the 170 Montauk has less wetted surface on plane and consequently, will reach a higher speed. I"m still trying to the older design hull to go faster. Anyway, thanks to both of you for the inputs.
