  Propeller Recommendation: 90-HP Yamaha on 16-SL
Author Topic:   Propeller Recommendation: 90-HP Yamaha on 16-SL
mightymight posted 04-15-2003 06:47 PM ET (US)   Profile for mightymight   Send Email to mightymight
I have a 1992 90-HP Yamaha on a 16-SL dual console. The prop looks bent on one [blade]. Any recommendations for a new prop that is strong/Fast? Live in San Diego, seem to catch myself in kelp quite often. Someone mentioned the chrome dual props. Are these ok for this outboard?
Thank you!
jimh posted 04-15-2003 09:31 PM ET (US)     Profile for jimh  Send Email to jimh
Using a propeller which has bent or damage blades is a bad idea. The unbalance from a damaged blade will cause vibration. This could damage the seals on the lower unit.
A "strong/Fast" propeller sounds to me like a stainless steel propeller.
"Chrome dual props" are not really chrome, they are probably stainless steel, and they are called "duo-props."
As far as I know the duo-prop design is not applicable to your 90-HP 1992 Yamaha. A duo-pro propeller requires two propeller shafts that are coaxial and counter rotating.
I would recommend you replace your propeller with a Stainless Steel Yamaha OEM propeller of similar size to the original.
Ramhouse posted 09-25-2009 01:18 AM ET (US)     Profile for Ramhouse  Send Email to Ramhouse
To mightymight.
I just picked up a 16sl. Id like to talk to you. im in Corona, cccca.
Richard ramhouse@sbcglobal.net
Ramhouse posted 09-25-2009 01:19 AM ET (US)     Profile for Ramhouse  Send Email to Ramhouse
its ramhouse@sbcglobal.net
