  Just ordered my new Montauk trailer.
Author Topic:   Just ordered my new Montauk trailer.
Bigshot posted 05-13-2003 11:53 AM ET (US)   Profile for Bigshot   Send Email to Bigshot
Loadmaster aluminum trailers are made in Brandon, FL just south of Tampa. They make just about every aluminum trailer made including OEM manufacturers such as Donzi, Hydra-Sports, Contender, Sea Craft, Wellcraft, Concept....the list is LONG.
Anyway they are among the best made trailers you can get. If anyone is interested in having one made let me know but this is the deal.
15-17' trailer with torsion axle, PVC guide posts, submersible lights, Alum diamond plate fenders, heavy duty 2 speed winch with strap. Galvinized hubs with some auto-lube stuff(not bearing buddies), 14" galvanized rims and Goodyaer tires. 3500lb capacity is $1135. I added stainless steel kit which means every bolt, nut, washer, u-bolt etc is SS. $110. I also got SS acorn lugnuts so mine won't rot off or on again $15. And LED taillights that are totally sealed and have a 10yr warranty $35. With tax out the door is about $1387. 14" aluminum mags(like bass boats use) are another $150pr but I did not get them.
Now the cool thing is they are making it for me so no decals are being put on the trailer. I gave him some custom made 18' long red Whaler harpoon decals(look like a red harpoon) which they will istall for FREE. This will be a bad looking rig for my montauk when done, especially with that little custom flair to it. This is my 3rd Loadmaster and I am very pleased. I will send a pic(when finished) to Jimh for any upcoming Cetacea article pertaing to trailers.
Never knew I could get so excited over a trailer.....puzzling!
Jimm posted 05-13-2003 02:11 PM ET (US)     Profile for Jimm
Easy, big fella - although it does sound good.
dww posted 05-13-2003 02:20 PM ET (US)     Profile for dww  Send Email to dww
Bigshot,
You have given me some trailer advice in the past, and in fact talked me into buying "new". I have just posted a thread asking what the appropriate number of keel rollers are for my 13'BWS. The EZ loader I looked at has two (one fore and aft). I understand these are very important in trailering these boats. Any thoughts?
lhg posted 05-13-2003 02:32 PM ET (US)     Profile for lhg
Sounds nice, Nick. Did you buy the upgrade to double Stoltz keel rollers on each crossmember?
Let us know how you like those new Spindle-Lube axles. I know Champion trailer and Continental are also now using this system. I have been afraid to try that system out, since although it pumps grease directly into the axle and to the back of the bearings, then purges it out the front, there doesn't seem to be any pressure device to keep water out. Bearing Buddies have worked for me so long that I'm afraid to try anything else.
NHKatama posted 05-14-2003 01:27 AM ET (US)     Profile for NHKatama  Send Email to NHKatama
I drove a loadmaster trailer up from Tampa to NH back in April. I have my 1972 Katama on it. I love this trailer. I stayed with the 13" rims, got the led lights and spare tire with hub, also full SS kit, and I also added a stolz roller to the vee bar and added two keel rollers to the back and middle cross members. I had to play around with the keel rollers to get them just right, but now that I have them adjusted I have good support with two 7' long bunks, and three big keel rollers. Also, I had Loadmaster shorten this trailer by 2' they did this by doing a shorter tongue wrap, like the continental trailer uses. This way the trailer fits in my shed.
Anyway I may go back down there in about 6 months and if anyone is interested I will bring some trailers back, need 5 to 7 people to make it worth the trip so let me know, can deliver along the east coast on way back to NH.
Blue skys to all, ~~~~Pete
Bigshot posted 05-16-2003 12:19 PM ET (US)     Profile for Bigshot  Send Email to Bigshot
Good idea Pete. I know one guy in SC that is interested.
I did not order keel rollers, I do not think they are necessary but that has been debated enough. If I did get keel rollers then I would have to get an electric winch and really get lazy. With my trailers I just drive it in and float it on and winch up the last 2 feet.....VIOLA!
dww posted 05-16-2003 01:31 PM ET (US)     Profile for dww  Send Email to dww
Bigshot,
How big is your boat? Have you noticed any ill effects from using a straight bunk trailer?
lhg posted 05-16-2003 01:48 PM ET (US)     Profile for lhg
Did I tell you his boat has two long grooves in the bottom, where it sits on the 2 bunks!
dww posted 05-19-2003 10:23 AM ET (US)     Profile for dww  Send Email to dww
No you didn't tell me, but I really appreciate the poignant observation. Good work.
triblet posted 05-19-2003 11:02 AM ET (US)     Profile for triblet  Send Email to triblet
Bigshot said the trailer was for his Montauk.
Lots of folks here (me included) have whalers
on straight bunk trailers and there have been
zero reports of problems because of this. And
my owners manual says its OK.
Bigshot posted 05-21-2003 02:58 PM ET (US)     Profile for Bigshot  Send Email to Bigshot
My boat is a 1989 and has always sat on a bunk. I have bunks that are cut on an angle and rest perfectly under both inside chines. If my chines can't handle the weight then Whalers are not worth a squirt of.......WD40. NO chine should EVER warp. If you have your bunks just resting on the flat part of the hull, better get some keel rollers.
Royce posted 05-22-2003 06:51 PM ET (US)     Profile for Royce  Send Email to Royce
Larry- I also have the spindle-lube axles. I like the fact that the back bearings recieve fresh grease when you lube them and that you can force most of the old grease out of the front without removing the hubs. I am installing Bearing buddies on the hubs to keep a little positive pressure on the system as well as to repace any grease that might escape. This seems like the best of both worlds. What do you all think?
Royce
David Jenkins posted 05-23-2003 01:37 PM ET (US)     Profile for David Jenkins  Send Email to David Jenkins
My 15' Whaler weighs too much for my current trailer. And someday I plan to buy a 16/17. So if I have to buy a new trailer now, I would love to buy one that I could use with either boat (so if I did by a 16/17 I could sell that old trailer with my 15 and use the new trailer with my new boat). Would one of the trailers rated for 3500 pounds work with a 15 or would it just be too big?
elaelap posted 05-23-2003 01:46 PM ET (US)     Profile for elaelap  Send Email to elaelap
I want one. Now. But I live in N. Calif. Any ideas?
Tony
rubadub555 posted 05-27-2003 01:48 PM ET (US)     Profile for rubadub555  Send Email to rubadub555
The local Continental trailer dealer believes that a two keel-roller set up (with bunks, of course) is sufficient to support my 1980 Montauk?
Anyone have an opinion?
Should I pay up for dual keel rollers on each cross-member?
If my keel is already scarred from years of black rollers, is there any point in Stoltz rollers?
lhg posted 05-30-2003 03:43 PM ET (US)     Profile for lhg
Royce - Be extremely careful of using a Bearing Buddy over the Spindle Lube!! The reason I say this is because I did this on my own trailer, and had a total failure, with wheel falling off, fortunately only in my storage yard. I think the end of the Spindle Lube did not clear the BB adequately, and the spindle lock washer came loose, allowing the bearings to fail.
If you have Spindle Lubes, I would not use the Bearing Buddies. Because the failure damaged my spindle, I replaced both axles with the conventional design and am again using Bearing Buddies. I'm just more comfortable with the older, proven design.
I have wondered for some time how the Spindle Lube system keeps water out of the bearings, absent pressure. That's why I'm afraid of it.
triblet posted 05-31-2003 12:36 AM ET (US)     Profile for triblet  Send Email to triblet
rubadub, BW says either all-bunk, or lotsa
keel rollers. Two keel rollers in the
in-between.
Stoltz is really well made in more ways than
just not putting black on your gel coat.
Do it, IF you have rollers.
triblet posted 05-31-2003 12:37 AM ET (US)     Profile for triblet  Send Email to triblet
That should have read "two keel roller is IN
the in-between" (i.e. not recommended by BW).
David Jenkins posted 05-31-2003 06:34 AM ET (US)     Profile for David Jenkins  Send Email to David Jenkins
Do you really need a trailer rated at 3500-pounds? Wouldn't a trailer rated at 2000 pounds be sufficient?
beaufort posted 05-31-2003 10:24 AM ET (US)     Profile for beaufort  Send Email to beaufort
I chose an all aluminum, stainless steel Rolls Axle trailer. Incredible quality! I chose 17-19' 3500 capacity w/14" wheels. $1900. My 88 Montauk slides on and off w/ease and is a pleasure to tow at highway speeds.
Didn't see anyone mention this trailer in all my research on the Wave. Here's the link to the website:
http://www.rollsaxle.com/boat_trailers.htm
Bigshot posted 06-02-2003 12:00 PM ET (US)     Profile for Bigshot  Send Email to Bigshot
I am thinking of stepping up to the 17-19 in case I do get my 18 outrage one day.....only another $150 or so.
Bigshot posted 06-02-2003 12:01 PM ET (US)     Profile for Bigshot  Send Email to Bigshot
Ps...reason for 3500lbs is the 14" rims. With the 13" it is 2700lb capacity.
bsmotril posted 06-03-2003 01:36 PM ET (US)     Profile for bsmotril  Send Email to bsmotril
Were they able to build and set up the bunks without the boat? Or do you have to adjust the bunks when you receive the trailer? I am wondering if they build so many trailers that they have templates to set up the bunks for common boat models.
billS
Bigshot posted 06-03-2003 03:58 PM ET (US)     Profile for Bigshot  Send Email to Bigshot
They say they are able to set it up without the boat but i have already measured my bunks on my old trailer to compare. The new bunks are also going to be 4" shorter(lower) for a lower center of gravity. Should be sweet if I don't cancel my order first being my boat is in surgery.
wriling posted 09-08-2004 08:24 PM ET (US)     Profile for wriling  Send Email to wriling
Pete,
If you are getting ready to make another trip I would be really interested in one of these trailers.
Please let me know.
Regards,
Wendy
