Topic: 17 montauk repower
awaikart |
posted 08-07-2003 01:53 PM ET (US)
I have two questions. One what is the max hp on a 1974 montauk. The other is I have a 100 hp mercury and I need to put it my 17 whaler. The well is only 9 inches and the bottom bolts are below the deck. I dont want to use a bracket. Any suggestions would be appreciated.
Bigshot
posted 08-07-2003 02:03 PM ET (US)
100hp is max so you can use it. To get the bottom bolts in you must raise the engine about 1.5" off the top of the transom. I have a jackplate and love it so if nothing else works, worth the $150. |
Jamie 20 outrage
posted 08-07-2003 08:18 PM ET (US)
What I did is angled the bolts to reach the well. I have read on this forum that others use a long bit and threaded rod to go through the well. I think either is good, anything is better than lag bolts. |
TRIDENT
posted 08-13-2003 02:39 PM ET (US)
100 HP is max for the Montauk. I would go ahead and buy a manual jackplate that will match up with the current bolt-holes. It will help your performance and installation for $150. Good luck. |
