  Performance data: 1994 Outrage 24 w/ 225 Johnson
Author Topic:   Performance data: 1994 Outrage 24 w/ 225 Johnson
PMUCCIOLO posted 09-09-2003 09:34 PM ET (US)   Profile for PMUCCIOLO
Here are some numbers on our 1994 Outrage 24 with her single 225HP Johnson. Fuel consumption data is not available. This information was obtained with a ten to fifteen mile-per-hour headwind, moderate chop, and minimal current. Two people were aboard, approximately one hundred gallons of fuel, and moderate gear. The bimini top was in the arch position, but zipped up in its boot. The numbers are from a Garmin GPS.
3400 RPM 24.4 MPH
3500 RPM 25.3 MPH
3700 RPM 26.8 MPH
4100 RPM 30.9 MPH
5000 RPM 37.5 MPH
5400 RPM 40.7 MPH
The engine is mounted on the third hole from the top and is swinging a 17" OMC Viper propeller. Next, the numbers for the lower end of the RPM range will be recorded. The boat stays on a solid plane at 3100 RPM's as above. That's quite impressive considering her bulk and weight.
Paul
peteinsf posted 09-10-2003 12:36 PM ET (US)     Profile for peteinsf
Paul,
Do you have trim tabs on her?
Pete
Sal DiMercurio posted 09-10-2003 03:24 PM ET (US)     Profile for Sal DiMercurio  Send Email to Sal DiMercurio
P., i kinda feel your gps just might be off, as those are really impressive speeds for that big of a boat with only that much hp on her.
If i'm wrong, thats some darn good speeds with a 22five [ printer wont print the number five ].
Sal
PMUCCIOLO posted 09-10-2003 03:41 PM ET (US)     Profile for PMUCCIOLO
peteinsf,
She has a flush mounted tabs which appear at first glance, relative to the boat's size, small. However, they must be positioned perfectly, as slight adjustments are all that is necessary to keep her level in a cross wind.
SSILVER posted 09-10-2003 03:50 PM ET (US)     Profile for SSILVER  Send Email to SSILVER
Sal if your using a 101 K-B there should be another 5 button, if its a laptop there is probally a dual function key that produces a 5.
Sean
Sal DiMercurio posted 09-10-2003 08:06 PM ET (US)     Profile for Sal DiMercurio  Send Email to Sal DiMercurio
Sean, thanks on that heads up, I didn't even think about it.
5 5 5 5 5 5 5 5 5 5
Sal
