  17'Outrage needs power (90hp Honda?)
Author Topic:   17'Outrage needs power (90hp Honda?)
Bob Zollo posted 09-11-2003 09:03 PM ET (US)   Profile for Bob Zollo   Send Email to Bob Zollo
1998 17' Outrage needing to be powered .How about a 90 honda will that push the boat ok ? BZ
Jerry Townsend posted 09-12-2003 10:56 AM ET (US)     Profile for Jerry Townsend  Send Email to Jerry Townsend
Bob - I have a '96 17 Outrage with a 115 Johnson Ocean Runner - which is a good compromise - gets right up on plane and moves right along at 25 - 30 at 4000rpm. Therefore, you might be on the light side with the 90. Bear in mind though, I am up in the air about 5000 feet. ------ Jerry/Idaho
Kevin Bliem posted 09-13-2003 08:56 PM ET (US)     Profile for Kevin Bliem
i have a 98 17 outrage w/ a 135 merc. itmoves nice. the max is a 150. I would be careful w/ a 90... nothing worse than not enough power.
Eddie Mucciolo posted 09-16-2003 12:36 PM ET (US)     Profile for Eddie Mucciolo  Send Email to Eddie Mucciolo
I have a 1998 with a 150 Mercury carb. I just purchased the 150. I had a 115 saltwater that came with the boat. The 115 was a minimum for me and I wanted more speed. The Honda is heavy and underpowered for the Outrage. If a storm is coming or you want to outrun some of the new big fast boat wakes you need a minimum of 40mph. 115 would be the least I would have on my boat.
sixknots posted 09-24-2003 02:06 PM ET (US)     Profile for sixknots  Send Email to sixknots
I have a 97 Outrage with a 135 Merc. Works fine -- planes quickly and has pleanty of speed. I wouldn't go below a 125. Max is 150.
prm1177 posted 09-24-2003 02:50 PM ET (US)     Profile for prm1177  Send Email to prm1177
Much depends on what you're using the boat for. I too have a 17 with a merc 135. Fast enough with the right prop and motor height for me to take 4 people fishing at good speed. I'm comfortable towing skiers and tubes as well. 90 HP would get the boat on plane, but might prove under powered with a full tank (53 gallons) and a full load (7 adults max). The Yamaha 150 4 stroke looks mighty inviting.
