  Welcome to Johnny Talk!
Author Topic:   Welcome to Johnny Talk!
BugsyG posted 10-08-2003 07:35 PM ET (US)   Profile for BugsyG   Send Email to BugsyG
Hi fellow Whaler'ers!
I found the plate on my Johnny stating the range of which to run her at.
70 hp. 1984 Johnson -- Rebuilt 2 years ago
It simply stated that it should be ran from 4500-5500.RPM's
BIA at 5000RPM's (What the heck does that mean?/!)
And something else like PIS or something with a "P" in it at 5000 RPM's
I run her from 3800-4000 RPM's @ 25-28 MPH. WOT is 4800 @ 34 (Clean bottom) Is that right? Could someone please shead some light on the subject of what the plate means? Thanks a lot for participating in Johnny Talk!
~JAZZ~
Bigshot posted 10-09-2003 11:01 AM ET (US)     Profile for Bigshot  Send Email to Bigshot
4500-5500 is WOT(wide open throttle) range. In other words you should be between 4500 & 5500 when she is mashed to the console and obviously the linkage is allowing you full throttle. What size prop are you running Jazz? 4800 is on the low side. I would drop down 2" of pitch and get her up into the 5200 area. You should be running a 17" prop.
BIA is Boating Institue of America I believe and they rate your engine at 70hp @ 5000 rpms.
hooter posted 10-09-2003 01:08 PM ET (US)     Profile for hooter
Ah'll talk in the john if propriety demands sociability, but usually Ah prefers t' keep mum and CONcentrate.
Nothin' woise than a gott-damm, slap-happy gabber runnin' on in the crapper:-!
BugsyG posted 10-09-2003 06:16 PM ET (US)     Profile for BugsyG  Send Email to BugsyG
Bigshot,
I am running a 13.25 X 17" Pitch. Aluminum Job. I thought about stainless but its $$$$$$. My prop is about 2 years old. No nicks or dings in it. Just the paint is coming off of it.
Hoots, you crack me up!!!!!
JAZZ
Bigshot posted 10-10-2003 11:27 AM ET (US)     Profile for Bigshot  Send Email to Bigshot
She is either mounted too low, tired or waterlogged hull. You should be doing better than that and up in the 37+mph area.
ryanwhaler posted 10-10-2003 08:48 PM ET (US)     Profile for ryanwhaler  Send Email to ryanwhaler
JAZZ had the motor rebuilt two years ago. So I don't think the motor is tired.
Jazz,
Have you ever took your boat to a truck stop to, check the the weaght?
Bigshot posted 10-13-2003 10:40 AM ET (US)     Profile for Bigshot  Send Email to Bigshot
Rebuilt is in the eye of the rebuilder.
