posted 11-09-2003 01:25 PM ET (US)
76er,You're welcome for the advise but I don’t recall giving it. In fact, I don’t think I would have made that recommendation but I hope you enjoy your new motor. I'm sure it will serve you well.
The only thing you can do with your rails apart from replacing them entirely, is to cut them at the location of the Tees and insert what is called a "Hot Dog" with is a 4" long piece of 3/4" stainless steel tubing which will work as a spline to hold the two severed rail parts together.
I have not done this myself but it is reported that it works quite well. Some factory Railings were built by Whaler using the Hot Dogs. I believe you could even order the part from Whaler. In the 1980's the Whaler part number for a Hot Dog was #72109304. Any Whaler dealer should be able to cross reference this number with the new one but of course, you could just go buy a short section of the correct diameter stainless steel tubing and cut your own.
