  Over powering a 15 Johnson vs. Mercury
Author Topic:   Over powering a 15 Johnson vs. Mercury
pimpinawhaler posted 01-14-2004 08:27 AM ET (US)   Profile for pimpinawhaler   Send Email to pimpinawhaler
I am interested in putting a 2004 johnson 90hp or a 2004 mercury 90hp on a 15 super sport limited. The problem it weighs 335pounds"johnson" and 303"mercury" does anyone know if it will handle the weight and the water would drain properly or does anyone know which is a better motor. Thanks Taylor
Bigshot posted 01-14-2004 11:46 AM ET (US)     Profile for Bigshot  Send Email to Bigshot
They handle the weight pretty good. as far as draing, depends on what you mean. Even with a 40hp you can't leave the plug out.
cape_rover posted 01-14-2004 04:37 PM ET (US)     Profile for cape_rover  Send Email to cape_rover
I was considering repowering withe 90hp yamaha. It is a 3 cyl. I would not put a 4 cyl on (I'm not sure how many cyl'ers the engines you referenced have). I have seen the 15' with a 90 yamaha and it sat fine in the water.
pimpinawhaler posted 01-14-2004 05:52 PM ET (US)     Profile for pimpinawhaler  Send Email to pimpinawhaler
The compartment i was refering to is the one that is molded in the transom it has 2 plugs and also the motor i was looking at is a 4cyl.I seen someone who had a mercury 90 "303lbs" plus a jack plate and hyd. steering and it looked fine it is on page 50 in the pics so i was thinking that the 30 or so pounds would be the weight of the jack plate and the steering Thanks alot Taylor
