  Evinrude 70-HP Maximum Engine Speed
Author Topic:   Evinrude 70-HP Maximum Engine Speed
rsgwynn1 posted 01-14-2004 10:27 AM ET (US)   Profile for rsgwynn1   Send Email to rsgwynn1
How many RPM should a c.1985 Evinrude 70-HP turn at wide open throttle?
Bigshot posted 01-14-2004 11:47 AM ET (US)     Profile for Bigshot  Send Email to Bigshot
Depends on what year. Up to 1985 I believe they redlined at 5500. From 1986 or 1987 on they redline at 6,000. What is your model # so I can check the year.
rsgwynn1 posted 01-14-2004 09:01 PM ET (US)     Profile for rsgwynn1  Send Email to rsgwynn1
It's an 1985--E70ELCOS
JBCornwell posted 01-14-2004 09:21 PM ET (US)     Profile for JBCornwell  Send Email to JBCornwell
Your engine is a 1985, RSGwynn.
5500rpm redline.
Red sky at night. . .
JB
rsgwynn1 posted 01-14-2004 10:00 PM ET (US)     Profile for rsgwynn1  Send Email to rsgwynn1
Thanks. I believe I'm a little short on prop.
whalersman posted 01-14-2004 10:08 PM ET (US)     Profile for whalersman  Send Email to whalersman
The common props used on that engine are the 13 1/4 x 17" pitch or the 13 3/4 x 15" pitch..
The 17 gives you a little more top end and the 15 gives you a little better hole shot.
I used both props at different times on my 1985 Evinrude 70 hp on my Montauk... Yours is the same engine as mine was..
Wide Open Throttle should be between 4500 and 5500 RPM Max...
Joe
jimh posted 01-14-2004 11:22 PM ET (US)     Profile for jimh  Send Email to jimh
[Administrative post]
where2 posted 01-16-2004 12:42 PM ET (US)     Profile for where2  Send Email to where2
With a 15' classic whaler hull, you can actually run a 13"x19" Stainless with cupping on an '85 Johnson 70Hp engine. Just don't try to pull up slalom skiers with this prop on the engine.
With my 13-1/4"x17" cupped aluminum, it will actually spool up higher than redline at Wide-Open-Throttle (WOT).
If the hull is a 17' classic, use the props whalersman suggested.
rsgwynn1 posted 01-16-2004 11:17 PM ET (US)     Profile for rsgwynn1  Send Email to rsgwynn1
This is on a 14 ft. McKee Craft that I'm restoring. I think the hull is very close to the Whaler 15. I just got a used ss prop, slightly dinged up, that looks to be a 19, so I'll give it a run to see what rpms I get before I take the prop to the shop to have it redone and maybe repitched.
Propeller Head posted 08-27-2007 01:56 PM ET (US)     Profile for Propeller Head
I have a 1986 70 Johnson VRO on a 15' Striper. Is the max RPM 6000 for this year motor? Model # is J70TLCO.
Tohsgib posted 08-28-2007 11:48 AM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
Actually your model # says 1985 and no that is 5500. 86 is 5500 as well, I think 87 started the 6k.
Propeller Head posted 08-28-2007 02:04 PM ET (US)     Profile for Propeller Head
Thanks...
