posted 03-02-2004 11:53 PM ET (US)
GCL:I've had a little experience with several trolling plates.
I've used the Happy Troller, Hydro-Troll and Hydro-Troll II all purchased from Cabela's. I ran them on my Montauk with an 80HP and on my Outrage 17 with a 115HP.
The Happy Troller didn't have a release pin so if you ever forgot to lift it up before hitting the throttle, it will bend and basically ruin the unit. I did it and my buddy did once and that about did it for the not so Happy Troller.
The Hydro-Troll and Hydro-Troll II both have a brass shear pin that is "supposed" to break if you forget to release it. Once released, it is "supposed" to lock in place. My experience has been it doesn't lock in place very well and I had to manually put it up in the running position. That meant I had to raise the motor all the way up and grab the plate and lock it into place. This was quite a pain.
The shear pin didn't always break as designed. Cabela's customer support stated this was a known issue or that customers had reported similar experiences.
Since I don't have a need to troll at real slow speeds anymore, I just last week sent back my Hyro-Troll II. It was my third replacement that Cabelas had sent me. They are very good about refunds/exchanges, etc. I just decided why install it if I'm not going to use it. I can troll around 2.6 mph without a plate and that has worked fine for me.
A kicker motor can be a good option (expensive though) but I'd recommend an EZ-Steer or some similar device. I used a Helsmate ext tiller on my kicker and that was somewhat of a pain. Never could sit down.
Hope this helps...
Marc...
